E85 or meth?
Old Jan 6, 2011 | 09:31 AM
evopowned's Avatar
E85 or meth?
So I've been doing alot of reading lately on e85 and water meth. And can't decide witch route to chose so decided to post a thread to get different opinions from both users. Thinkin about e85 mostly cause it just seems safer. But only think makin me think about meth is e85 is 2.86 a gallon where I live and the only gas station that caries it is ten miles from my home my Evo is not my dd so wouldn't be horrible but been reading average mpg is ten. So that's a downer. Lookin at meth seems to have about same gains but if the system ever fails it can be very bad news from what I hear still a novice at these alternate fuels but any info on either or opinions from users would be sweet. Im gonna continue browsing the forums for more info! :cheers:
Old Jan 15, 2011 | 01:18 PM
ronitlancer's Avatar
I am in the same boat, looks like nobody wanted to reply though.
Old Jan 15, 2011 | 01:30 PM
LOVEBOOOST's Avatar
E85 is only ten miles away....and ur evo is not ur daily. There is no question to whether I would be tuned for it....I wish we had an E85 station around us...must b nice!!! Go for it u will never look back!!!
Old Jan 15, 2011 | 04:01 PM
Jim in Tucson's Avatar
E85 does require a higher commitment.
However, knowing that I'm spending much more on fuel, but sending far less of each fuel dollar to foreign oil producing countries who refer to the US as the great Satan, is worth it in my opinion.
Old Jan 15, 2011 | 05:02 PM
tscompusa2's Avatar
If its not a daily driver then definitely E85.
1. E85 will outperform race gases 116oct+ (Rated 104oct but all alcohol fuels are rated low - will outperform C16 & Q16)
2. E85 will lower your exhaust gas temp and intake temps 20-30f or more easily
It does require 30% more fuel supply though, so you will most likely need to upgrade your fuel system to accommodate for it.
Old Jan 15, 2011 | 05:49 PM
Boltz.'s Avatar
FCOTM Winner
Meth will lower your intake temp by evaporating in the charge pipe, dissipating the heat. I don't understand how you're claiming E85 will lower the intake temperature.
Old Jan 15, 2011 | 06:06 PM
tscompusa2's Avatar
research before questioning someone.
http://en.wikipedia.org/wiki/E85#Com...gular_gasoline
taken from the e85 forum:
E85 combusts at a lower temp, and also draws more heat from the intake manifolds due to its higher L H o Vaporization. These effects cause most engines to run at 10-15degF lower temperature (at coolant) when using E85
also yes, I know methanol injection will also cool the intake. So when comparing meth injection to e85 of course its not 30-40F.
Old Jan 15, 2011 | 06:08 PM
dscevo8's Avatar
I wish E85 was more readily available at the pumps. there wouldnt even be a debate on what to choose if that was the case
Old Jan 15, 2011 | 06:09 PM
BoostWhore's Avatar
e85 no questions asked or dont do it
Old Jan 15, 2011 | 06:12 PM
tscompusa2's Avatar
meth injection is effective as well dont get me wrong. i was tuning a guy with really poor fuel. we couldnt even run 1* past 5k rpm and so i had him dump a gallon of vp import in and the knock completely dissapeared. we believe the fuel was 87octane.
had him burn off the excess in the tank and refill with the crap fuel again and turn his 900cc of vp methanol injection setup on and ended up with 17* where before the car wouldnt even run 1*.. so yes meth injection is highly effective.. but when comparing to e85 its not even in the same league.
E85 is rocket fuel from hell.
Old Jan 15, 2011 | 06:20 PM
RockmanX's Avatar
YES SIR ROCKET FUEL FROM HELL. the only reason to run meth would be in the above situation or its not available and having tuning issues other then that avoid it. E85 does require a fuel system upgrade as mentioned but i have seen cars make upwards of 50-100whp more on just only adding e85 its crazy
Old Jan 15, 2011 | 08:03 PM
tscompusa2's Avatar
http://webcache.googleusercontent.co...&ct=clnk&gl=us
Old Jan 15, 2011 | 09:18 PM
S13 Curtis's Avatar
I use methanol injection because i daily drive my evo. The e85 is too far so ill stick with meth.
Going 2.4LR w my HTA86 on meth nxt year.
Old Jan 15, 2011 | 09:57 PM
teeho's Avatar
Definitely should take advantage of E85 if you have it near your area or stock up on 10 gallon jugs!
evo_ten_mr
For Sale - Wheels / Tires
Sep 12, 2013 02:24 PM
Piro Fyre
Sep 9, 2011 09:42 PM
tvor
27
Feb 1, 2010 10:07 PM
project_skyline
E85 / Ethanol
39
Aug 10, 2009 01:31 PM
evane
58
Oct 28, 2008 04:22 PM
