Converting to e85
Old Oct 28, 2011 | 01:03 PM
SmurfZilla's Avatar
Ran my evo IX turbo up to 29 psi on E85. I had PTE 1200's.
Old Nov 24, 2011 | 07:51 PM
Steelo's Avatar
Ran my cook with stock turbo at 28psi with pre 1000's. Made 330whp/360wtq.
Old Nov 24, 2011 | 07:53 PM
Steelo's Avatar
[QUOTE=Steelo;9772479]Ran my viii with stock turbo at 28psi with pte 1000's. Made 330whp/360wtq
Old Dec 4, 2011 | 11:23 AM
CDrinkH2O's Avatar
What's a cook
No seriously I'm making the same transition to E85 on my stock viii daily driver. I'm going to run FIC 1050's with boost set to 26 psi at peak torque tapering to 22psi at redline. This is easy to do with a GM 3 port BCS.
Don't forget if the winter blend in your area changes to E70 (for better cold starting) this will make you run leaner and require a retune. Or if you want to get in to this for real, grab EcuFlash and start learning.
Old Jan 11, 2012 | 11:16 AM
arco's Avatar
nice numbers
Old Jan 11, 2012 | 04:30 PM
Benja's Avatar
Round the other way mate.
Lower ethanol content = richer AFR
Higher ethanol content = leaner AFR
Old Feb 19, 2012 | 04:59 PM
gpfury86's Avatar
^^^^ what he said...... Higher ethanol content and you're going to lean out some....... As long as your not tuned to the ragged edge it should be alright. Ecu flash is your friend I try to keep my afr's around 12-12.3 on e85
Old Mar 3, 2012 | 02:43 PM
omar310's Avatar
Wat up everybody. Ive been reading a lot on e85 n from wat u guys are saying I think I want to do the conversion as well. Ive got a few bolt ons nothing major, how do I go about this, n wat do I need? I have one other question, is it possible to get better mpg on e85, if its tuned to?
Old Mar 3, 2012 | 03:05 PM
4RETECH's Avatar
Go to the alt fuel section and read up on it. Injectors, fuel pump, and a tune.
Less fuel mileage,somewhere around 30% less......
Old Mar 6, 2012 | 08:45 PM
omar310's Avatar
damn lol, i thought maybe one of you evo tuning gurus would have thought of how to get more mpg aside from tuning 1000hp evos. im still going with e85 lol
clash0901
18
May 27, 2016 10:42 AM
IDRNKV8
89
May 14, 2014 10:01 AM
mirkendargen
10
Feb 29, 2012 08:32 PM
dsycks
E85 / Ethanol
12
Jun 20, 2008 10:59 AM
ArchieBabes
May 21, 2008 03:01 PM
