e85 cold start issue
Old Sep 18, 2012 | 06:38 AM
egis's Avatar
Guys is this normal cranking 30-40 seconds on cold start at 40 degrees?thanks
Old Sep 18, 2012 | 06:48 AM
escodotcarter's Avatar
not normal at all. might need to adjust your cranking tables. check with your tuner
Old Sep 18, 2012 | 09:44 AM
Solenoid's Avatar
Veteran: Marine Corps
^^^Agreed. Had the same issue years ago. Now, max of 2 (2 sec.) cranks & it fires right up
Old Sep 19, 2012 | 07:39 AM
egis's Avatar
Thanks guys.since you all run e85 you smell fuel or exhaust when you stop?I checked injectors they are not leaking.
Old Sep 19, 2012 | 12:46 PM
Where are you smelling the fuel? How did you confirm the injectors were not leaking?
(I was getting a whiff of fuel in the engine bay & found an upper injector seal torn)
There is a proper way to test for injector leakage but Ive never done it (its certainly not a visual)
My .02
Old Sep 19, 2012 | 01:01 PM
Ev0ikon's Avatar
If you don't have a cat you will smell fuel when you stop.
Old Oct 2, 2012 | 04:44 AM
siemens03's Avatar
Agreed with the above. It needs to be very rich on the crank tables.
Old Oct 4, 2012 | 12:46 PM
egis's Avatar
Yeah,I used simple method to check leaky injectors.I start the car and sprayed break cleaner around injectors area.idle didn't change.I run catless so now I understand why I smell gas when stop.never smelled on regular gas.tuner made rich from -20 to 80 degree,still same crap when around 40 degree.
Old Oct 4, 2012 | 01:10 PM
Ev0ikon's Avatar
Talking
"Brakes" cleaner is very corrosive for that area. Try starter fluid next time.
HPEVOX
Sep 8, 2012 10:38 AM
nsxiphos
Mar 6, 2012 03:25 PM
nytalonTSi
Dec 15, 2010 06:32 PM
Frank120
Nov 7, 2010 12:46 PM
black evil evo
AEM EMS
Oct 25, 2005 02:34 PM
