E85 Question....s
Old Sep 3, 2014 | 11:59 AM
EviLuTion21's Avatar
E85 Question....s
So I just have a few questions for any of the ethanol guys....my brother also has an evo but runs pump gas, mine runs e85, and he tells me mines running rich as crap according to my aem wideband a/f gauge. Im wondering if this is due to the ethanol, or is something broken, or if theres a better way to monitor e85 a/f ratio....thanks for all the input.
Old Sep 3, 2014 | 12:33 PM
Ev0ikon's Avatar
Tune it.
Old Sep 4, 2014 | 06:14 AM
It is tuned. But i feel like its reading that because its not really ment to monitor ethanol. Would changing the gauge to lamba help with a better reading?
Old Sep 4, 2014 | 06:17 AM
Ev0ikon's Avatar
Post a log.
Old Sep 4, 2014 | 11:40 AM
galantman03's Avatar
Its hard to explain but check it.
there's no need to try to convert the readings..the sensor originally reads in lambda then converts to a gas afr on the wideband..lambda never changes, and lambda is all that matters.
Basically the sensor reads lambda and sends the lambda values to the wideband gauge and then that does some math and displays the value as gas numbers. makes sense right?
Stoich, no matter what fuel, is 1.0 lambda, which is 9.7xx on e85 and 14.7 on gasoline. just different conversions based on burn rate and other factors. with that being said, you have a reference as to what you are at on e85, while reading it on your wideband that reads out gasoline afr's without doing the math.
Old Sep 4, 2014 | 12:43 PM
thepoint4life23's Avatar
Can you Change your wide band to read more for e85
Old Sep 4, 2014 | 02:11 PM
what? your display on the uego is just done by a math conversion. You take your lambda value that the wideband sensor pics up, and multiply it by xxx to get your 14.7 for gas value. I don't think the uego has a setting for e85, it would be cool if it did though
Old Sep 5, 2014 | 08:51 AM
Maybe i should change the spark plugs first. Considering theyre probably original. Lol. Ill check em and keep you guys updated.
Old Sep 5, 2014 | 08:52 AM
And thanks for all the help and info guys. Im pretty new to the turbo realm so bear with me and any and all info is much appreciated.
Old Sep 6, 2014 | 10:11 PM
Jp7's Avatar
Jp7
stoich is different for e85 and gasoline
14.7 vs 9.8 i think for e85
94AWDcoupe
44
Nov 6, 2017 08:40 AM
Cal3000
Aug 10, 2017 06:30 AM
ChipperEvo
Nov 18, 2016 01:06 PM
Chris@nolimitmotors
Evo 'For Sale' Electronics / Lighting / Audio
220
Mar 7, 2016 02:33 PM
2theMAX
E85 / Ethanol
Feb 25, 2013 12:35 PM
