Best pump to use for E85
People unknowingly tune around the pressure loss issue by richening up AFR in the fuel table. Reports of people swapping out a W255 for a higher flow pump system and seeing AFRs go much richer are the sign that the W255 wasn't working as it should and was causing the fuel system to operate below its target pressure. From the fuel system pressure logs I've gathered, I'd say 450 whp is a good safe limit for a punched W255 on stock fuel system with E85.
they really cant flow much more than a 1000cc injector anyway- with E85- its not doable-
We have rewired dw300's which worked well for basic setups to around 400-425 with a 1300 or so-
and rewired (for dual voltage) the walbro 450 (as hondaguy mentioned) with 1000+ cc injectors
cb
we cant even get close to 450whp on our mustang dyno with walbro 255-
cb
cb
My car was around 425ish, I think. IDC was WAY too high for my liking (90s), so we dialed it back.
I think it really depends on the horse power of the car and the size of the injectors. e85 burns 3xfaster then regular gas so the pump is gonna work that much harder. thats why high horsepower cars have 2 pumps, were on a stock build with bolt ons you can get away with a walbro 255 or the next size up.
Someone probably told you e85 uses 30% more fuel. That is different than burn rate.
The rest of your post is partially true, under certain circumstances.
I'm new in this and my first time owning an EVO and i want to go on E85 to get lil more HP. Just dont know what is the list to get to that. Would be a lot of help you guys can help me out. Thanks!!
