E85 Gauge w/ output for under $100
Old Dec 25, 2016 | 06:57 PM
  #31
mrb00st's Avatar
Originally Posted by ant_turbo
Hey buddy on both of the resistors does it matter 1/4-1/2-1/8 Watts... which on to use,,
THANKS,,,,,
any if fine, i personally used 1/4 watt
Old Jan 2, 2017 | 09:14 PM
  #32
ant_turbo's Avatar
Thanks,, Have another ?? how did you secure the wires to the Arduino..
Old Jan 9, 2017 | 12:46 PM
  #33
mrb00st's Avatar
I soldered all my connected on the back of the board. I WOULD have pictures except my phone got wiped and i lost them all.
Old Jan 9, 2017 | 03:21 PM
  #34
ant_turbo's Avatar
Ok thanks
Old Jan 10, 2017 | 01:41 PM
  #35
seven10's Avatar
Forgive my inexperience, but setting this up without using a patched rom would only allow for the car to switch between a main and alt map rather than interpolate between a mixture of maps, correct?
Old Jan 10, 2017 | 05:46 PM
  #36
ant_turbo's Avatar
Hey how do we upload the code,, and write it to the arduino,, do we copy the entire code that is written to the arduino,, we dont have to load a Library ??
Thanks, sirr
Old Jan 10, 2017 | 05:51 PM
  #37
Pal215's Avatar
OP,
You're a computer engineer or a computer science major aren't you ?
Very cool!
-pal215
Old Jan 11, 2017 | 01:03 PM
  #38
mrb00st's Avatar
Originally Posted by Pal215
OP,
Very cool!
-pal215
IT Administrator lol.
Old Jan 11, 2017 | 01:05 PM
  #39
mrb00st's Avatar
That is correct. No scaling at all like the patched roms. Just will simply switch maps once the output goes above the preset voltage trigger
Old Jan 11, 2017 | 01:06 PM
  #40
mrb00st's Avatar
Thanks, sirr
yes. copy and paste it. If you dont have the library, it should give you a error of which one you need. but these are the 3 library's you will need.
Wire.h LCD.h LiquidCrystal_I2C.h
Old Jan 11, 2017 | 01:44 PM
  #41
seven10's Avatar
Thanks for the clarification. Did you happen to try this with the FreeFuel patch at all?
Old Jan 11, 2017 | 06:27 PM
  #42
mrb00st's Avatar
I have not, have not wanted to spend the time putting together the map for my car lol
Old Jan 11, 2017 | 09:03 PM
  #43
deylag's Avatar
Cool thanks for posting this! I can't believe I missed this thread. It's well written and easy to follow. I already have a couple things on the list, so the most difficult thing for me will be plumbing up the fuel lines.
Did you come up with the code yourself?
Old Jan 12, 2017 | 08:25 AM
  #44
mrb00st's Avatar
i found the some of the code a long time ago. Made some changes to it and set it up to be able to display out to a 16x2 display.
Old Jan 12, 2017 | 09:15 AM
  #45
seven10's Avatar
Haha yeah it seems a bit tedious, but I think I'm going to try it out. I was able to to at least apply the patch to a fresh rom and I'll start porting over my current rom settings and see how things go.
