E85 Gauge w/ output for under $100
Old Jan 21, 2017 | 05:30 PM
  #61
mrb00st's Avatar
Originally Posted by spoolin turbo
Great mod and cheap too.
Any chance you can get some e98 to see if it will accurately read above 85%
The sensor should display up to 100%
Old Jan 21, 2017 | 05:31 PM
  #62
mrb00st's Avatar
Originally Posted by ant_turbo
What pin did you tap into the ecu for 5V,, and can I tap 12v switched from where I choose..
Thanks.....
im not sure im following? 5v for what?
Old Jan 21, 2017 | 09:10 PM
  #63
ant_turbo's Avatar
Pin 11/wire with the 3.3 coming from the Arduino
So connecting the pink wire is optional if i want to connect it??
Old Jan 22, 2017 | 09:13 AM
  #64
2jzftw's Avatar
Man, if someone could pre-package this I'm sure there would be many interested in purchasing if it were priced reasonably.
Old Jan 22, 2017 | 12:23 PM
  #65
mrb00st's Avatar
For pin 11 for the output. Will go to Pin 42 on the ecu for map switching
Old Jan 22, 2017 | 01:49 PM
  #66
ant_turbo's Avatar
But isn't necessary to connect ?? only if we want to map switch?
Thanks.
Old Jan 22, 2017 | 02:42 PM
  #67
mrb00st's Avatar
Thanks.
Correct. I dont have mine hooked up. i just use it to visually monitor it
Old Jan 22, 2017 | 03:47 PM
  #68
ant_turbo's Avatar
Thanks...
Old Jan 24, 2017 | 08:33 PM
  #69
ant_turbo's Avatar
Hey what version of the arduino program are you using to program the arduimo.
Old Jan 25, 2017 | 07:37 AM
  #70
mrb00st's Avatar
im currently on 1.6.10
Old Jan 25, 2017 | 02:17 PM
  #71
ant_turbo's Avatar
Is it normal for the lcd display to show a reading while only hooked up the the PC usb only,,
Old Jan 25, 2017 | 08:25 PM
  #72
mrb00st's Avatar
[QUOTE=ant_turbo;11704357]Is it normal for the lcd display to show a reading while only hooked up the the PC usb only,,
Honestly not sure, i never hooked it up without the sensor on my tech bench. In a earlier picture it was displaying fine?
Old Jan 26, 2017 | 07:00 AM
  #73
mrb00st's Avatar
i cant see my response i made last night lol. You posted a picture a couple days ago with the display looking normal. did you change something?
Old Jan 26, 2017 | 08:33 PM
  #74
ant_turbo's Avatar
It all ways showed some numbers readings.. when plugged into the usb pc... Need to go and test it in the car but it has been to cold here in colorado... Snow
Old Jan 27, 2017 | 01:40 PM
  #75
ant_turbo's Avatar
Hate to bug u again, is this ok the way I have both wire Leeds for the 5v on the arduino,,
