E85 Gauge w/ output for under $100
so i bought this board https://www.adafruit.com/products/1447 because i happen to be on the site buying the arduino...wondering if its still the correct board?
also, is the code on the first page still not set up for the 16x2? could i bother you for the 16x2 code if possible? Thanks!
That one is fine. Just more wiring.. I bought a lcd with the dimmer modulator all ready installed. And only use 4 wires.
And u can use the Arduino clones. Work the same.just way chaeper.. here is what I use..
Stainsmart 1602 with the lcd dimmer in.built in.
And a arduino clome Elegoo uno r3
And yes the code is still for the 16x2 lcd
O ya and if u want a much compact setup. Use the Arduino Nano.. and yes they do makes clones.. And they are under $10
IM BACK! lol sorry for the hiatus. Took a new job and havent had a lick of spare time. I recently updated the library, some users were having issues with getting it to work. So i added 2 folders and u just drag and drop.
Hey so I uploaded the code onto my arduino but when I wired up the lcd I am getting nothing. It does boot up and the screen lights up but no info is being displayed however my laptop shows that the loop is running and there is info being captured (0% eth. I think). We added the libraries from the folder linked in post #1. Any idea on the problem? Maybe I'm missing a proper library? Thanks for the help in advanced!
If they doesnt work, u will need to check your I2C address. Using this here. This will spit out what the address of your I2C is so you can adjust it correctly in the code for the sensor
