need help building fuel system
Old Jun 10, 2020 | 06:49 PM
raverthug's Avatar
Im currently doing a full build. MAP 2.0 hks 280 cams, 2150 injectors, MAP turbo 525 pump, bulletproof fuel hat and a few other goodies. The only thing I dont have ordered is the fuel pressure regulator and filter. Im looking at a fuel lab 515 series. would I want to go with the 25-90 psi or 90-125? This will be on E85
Old Jun 11, 2020 | 05:11 PM
CurseDSM's Avatar
I did an Areomotive fuel filter and a magnus afpr on my car. Remember your fuel pressure will be at 50 lbs with the 525 so I would go with the higher gauge
Old Jun 11, 2020 | 06:19 PM
raverthug's Avatar
Thank you. I forgot to mention I will be -8an feed -6 return
Old Jun 12, 2020 | 01:41 AM
CurseDSM's Avatar
Yeah that will be more then enough to do what your looking to do. Idk what your goals are for the car but sounds like a good solid foundation for fuel. I know I got deals on both my afpr and my filter was free so I couldn't pass it up.
This is the filter I run in my car
https://www.summitracing.com/parts/a...CABEgJ4sfD_BwE
Old Jun 12, 2020 | 04:27 AM
Biggiesacks's Avatar
I recently put a radium fuel filter in my evo. The mounting system they have for it is really nice, and makes for an easy install.
Old Jun 12, 2020 | 05:59 AM
raverthug's Avatar
I looked at aeromotive but they didnt have a polished one the was e85 compatible for 10 micron
Old Jun 12, 2020 | 06:34 AM
RazorLab's Avatar
Another vote for Radium. The filter setup is top notch.
Old Jun 12, 2020 | 05:28 PM
hutch959's Avatar
the 515 would be fine...
im not sure what you mean by this.
do you mean on the gauge?
Old Jun 14, 2020 | 02:21 PM
raverthug's Avatar
I know im going a bit overboard but id like to hit 550 on low boost and whatever on high boost
They make 2 versions of the fuel pressureregulator. One designed for 25-90 psi and one for 90-125. At least thats the way it appears to be
Old Jun 14, 2020 | 04:10 PM
RazorLab's Avatar
Base fuel pressure should be set to approx 43psi so you would want the 25-90psi version
aleZZ
Jan 7, 2013 05:27 AM
m7mad.a
Mar 4, 2012 05:33 AM
JDM_CEDIA
Lancer Engine Tech
May 10, 2010 06:56 PM
kf6ytc
Aug 30, 2006 01:53 AM
