Can Ethylol 95% purity be used instead of ethanol at 99.9% purity?
Old Dec 24, 2021 | 05:39 AM
Evo8life's Avatar
Hi guys,as title states can we use ethanol at 95% purity and mix it with 15% gas to form e85 or ethanol has to be at 99.9% purity to be used as fuel in our cars without causing any harm?Image of the 200L barrel of ethylol 95 i bought attached.
Thank you
Old Dec 24, 2021 | 07:54 AM
Without seeing the full label on that drum it appears the company that makes Ethylol 95 is: https://chemi.co.za/ethylol-95/
If your EvO has a true Flex Fuel setup cant you just run this at the 95% value?
Old Dec 24, 2021 | 08:02 AM
Evo8life's Avatar
the link you sent is the supplier for ethylol 95.
what im worried about is that if its useable as fuel or not because its 95% ethanol and 5% water.
i will be mixing it with gas my self if its useable.
but what i wanted to know is if this is useable as the normal ethanol people use in the us without causing engine damage.
Old Dec 24, 2021 | 08:40 AM
I understand. Im certainly not the guy to advise on the mixing details. Im strictly a pump E85 user. I was curious as to who the supplier was.
Cheers,
Old Dec 24, 2021 | 04:43 PM
hutch959's Avatar
does ethylol = ethanol
Old Dec 24, 2021 | 08:55 PM
Evo8life's Avatar
Yes ethylol is ethanol just different names
Old Dec 25, 2021 | 07:17 AM
whtrice's Avatar
Veteran: Air Force
It appears to be E95 then. The concern I would have is what is the 5%? Someone said water? That would not be good.
I would pour it out and see if you get phase separation. The water may separate at the bottom of the sample.
Ethylol is more a industrial product for printing and solvent applications not a fuel. If too much water then you will likely get more corrosion too. Personally I would use a purer Ethanol.
Old Dec 25, 2021 | 07:41 AM
Evo8life's Avatar
this is exactly the advice i was looking for.I will try to find 99.9% purity if i cant i will just go Wmi at this point.
JDMevoBOOST
E85 / Ethanol
19
Feb 21, 2018 02:50 PM
Turbo Kyle
E85 / Ethanol
11
Oct 15, 2008 12:03 PM
dsycks
E85 / Ethanol
12
Jun 20, 2008 10:59 AM
jjm4life
Feb 24, 2006 11:15 AM
