Updates for "ECUFlash for EVO, Subaru, 3rd Gen Eclipse" freeware??
Old Apr 25, 2006 | 07:24 PM
  #46
l2r99gst's Avatar
Originally Posted by b0ostedEV08
Oh I have found so many new maps and tested them on my car and a few customer cars already. My friend from Japan is coming in a few weeks for 2 months, and he will be working with me on making a datalogger software as well.
Originally Posted by MalibuJack
yeah I've been doing alot of research, also looking at some of the sourcecode of the basic logger and flash apps to see what I can do with it. This is certainly very exciting for me.
This is great news from both of you!
I can't wait to start using this. What I really, really hope could be done is for a way to monitor the knock correction, or knock retard, that is being done by the ECU. Possibly even find a way to set a value for the knock retard where the MIL can be flashed.
Eager to get started,
Eric
Old Apr 25, 2006 | 11:40 PM
  #47
RazorLab's Avatar
Eric
The subaru version logger can log knock correction so I don't see why somebody can't make the same type of thing for mitsu.
Old Apr 26, 2006 | 12:09 AM
  #48
R. Mutt's Avatar
Originally Posted by colby
The interfaces will be ready next week. You can take a look at tactrix.com if you'd like see what they look like, etc.
Colby
I have some questions before purchasing the cable:
How does the interface cable hook up. The usb and I'm concerned with the whitereflash connector shown here:
Where would this plug in exactly?
Also what drivers need to be installed for the various evo models..both US and JDM. Is their any documentation for such installation?
Finally, are their any other 'test mode' conectors that need to be linked before starting the ignition? I know on the impreza's they show 2 green connectors...but i do't know what's the scenario for Evos.
Old Apr 26, 2006 | 07:29 AM
  #49
budlong's Avatar
gato frito
bump for this product... its gonna be a cheap , effectice tool
Old Apr 26, 2006 | 07:44 AM
  #50
Zeus's Avatar
Originally Posted by budlong
"Not going to tolerate it..."
This subject is too important to allow ANY crap in this, or related threads... ANY!
Old Apr 26, 2006 | 08:01 AM
  #51
budlong's Avatar
i agree.
Old Apr 26, 2006 | 08:11 AM
  #52
donour's Avatar
Originally Posted by R. Mutt
Where would this
plug in exactly?
There are two plug under the dash by the driver's right knee. One is the OBD-II port, the other is the magic ECU data port.
Apparently the cable uses a standard USB client chip that should work on Windows+Mac+Linux.
d
Old Apr 26, 2006 | 10:22 AM
  #53
RazorLab's Avatar
There is another port by the OBD2 port. That is used when you are putting the ecu into flash data mode. COBB tuning uses that same thing with the accessport on Subarus as well.
Old Apr 26, 2006 | 10:29 AM
  #54
b0ostedEV08's Avatar
It's really easy to start learning about your EVO interface. I am pretty sure you know where's OBD II connector is located? It's another white connector beside it. That connector holds the programming voltage pin, to put your ECU into programming mode when you are ready to flash your ECU. I will also be working on an instruction manual and the basics of EcuFlash.
That connector is somewhat like Subaru "test mode" connector, but with the mitsubishi, it's integrated with the OBD II connector. And that programming voltage pin is controlled by software of EcuFlash.
Old Apr 26, 2006 | 10:53 AM
  #55
shiftdsm E's Avatar
Ordered cable and waiting on software...too bad i failed my programming class and can't really do anything except wait for someone to release a working full function flash/tune/datalog program...sorry im useless
Old Apr 26, 2006 | 10:21 PM
  #56
BSREVOLUTION's Avatar
if you have two evo's, do you need two cables?
Old Apr 27, 2006 | 02:20 AM
  #57
mchuang's Avatar
I knew it would happen, thank you guys this is great for the people who like to do it themselves
Old Apr 27, 2006 | 05:15 AM
  #58
MalibuJack's Avatar
Of course not.. Unless you plan on doing stuff simultaneously on both..
Old Apr 27, 2006 | 08:01 AM
  #59
chmodlf's Avatar
Where do you guys think would be the best place to learn where and/or what the addresses are?
Or should we wait for a template file?
Are there any books or online resources to learn? I have the "How to Tune and Modify Engine Management Systems" by Motorbooks Int.
Old Apr 27, 2006 | 08:50 AM
  #60
l2r99gst's Avatar
Well, that's the hard part. You have to know ECU code and find everything through disassembly. As mentioned in this thread, a lot is already done, and I'm sure more and more will be added as we go along.
Now that we mentioned this, what disassembler is being used and is there anything that the general community can do to help out?
Eric
