Updates for "ECUFlash for EVO, Subaru, 3rd Gen Eclipse" freeware??
Originally Posted by chmodlf
Where do you guys think would be the best place to learn where and/or what the addresses are?
Or should we wait for a template file?
Are there any books or online resources to learn? I have the "How to Tune and Modify Engine Management Systems" by Motorbooks Int.
I'm sure most tuners would not willingly give out that information since they paid alot of money to be the first to get the info..
However, give it time, this info will become widely available in the not too distant future.
Tuning in general is something you learn over time, any good book on tuning will give you a head start, also any book that teaches engine theory and how it works will help alot too, since things like timing and fuel ratios for power, and how turbocharging/supercharging affects compression, etc.. are all topics that one should understand anyway.
Originally Posted by l2r99gst
This is great news from both of you!
I can't wait to start using this. What I really, really hope could be done is for a way to monitor the knock correction, or knock retard, that is being done by the ECU. Possibly even find a way to set a value for the knock retard where the MIL can be flashed.
Eager to get started,
Eric
Eric
The Evo transfer rate is much slower which is why I generally like to log directly off the sensors themselves on evos
it will be interesting to see if anyone can work a way around the slow transfer rate on the evo and develop a better data logging application
Something like a Delta Dash is a really amazing product which makjes it easy to to a really great job
Originally Posted by MalibuJack
Wait for the template files, most of the information is found by disassembling the code and finding the "Data sections" of it and what each section of data is used for..
What I have figured out on my own was done through lots of trial and error
I am sure that when real computer engineers start to work on the code they will discover and identify a lot more functions than I have been able to find with my limited computer ability
As a tuner the unloking of locations is very exciting to me as it gives me the ability to give an even better tune
One of the areas I have been hard at work on with no success is the 0300 code settings
That a a few other CEL 's would be nice to tunr off as I can with my Suabru flashing equipment
Originally Posted by DynoFlash
The Subaru has a lightening fast interpahse in the OBDII - ECU - for example Delta Dash which offers a world class data logging application for the Subaru
One thing to consider here is the read time and write time of this program, if it works as advertised it will be very slow process of flashing the entire image. I would estimate 30 minutes on the write for each flash. I don't want anyone to forget that the Evo ECU has a 100 flash HARDWARE LIMIT. For those eager to jump into this and "play around" with it, you can easily reach the flash hardware limit of your ecu in no time and have your ECU stuck on the 100th flash. After that you need to buy a new ECU.
My suggestion is to ignore most of what you read and instead start with a stock map and make little changes at a time and see what effect they have on how the car feels, reacts and what the data logs say.
Very good and accurate data logging is key and a wide band and scan tool are required.
Taking your time, going step by SMALL step and recording the results of the small changes you make will give you a good learning process and give you a feel for what works and what does not work.
Once you have taken the time to master the simple process involved it becomes very simple to actually conduct "tuning " itself.
Just my two cents
Originally Posted by TTP Engineering
You are correct. Short of a new processor in the ECU, I cannot see an OBDII bump in sample rate.
The 100 limit is a threashold under which the memory is gauranteed to be accurate - it is possible to exceed that limit
I am more concerend with the realiability and function of the softwear itself - especially in a windows operating environment
If the softwear works without freezing up I think most users will be fine
Also - there was some discussion somewhere that the softwear only flashes the blocks you are changing which may make it faster than you have suggested
I guess we'll all have to wait to see how well it works in practice and I hope thyat it works really well
I am epsecially excited about the potential to flash the Lancers and 4th gen - I would love to work and figuring out some new ecus
Anyway - we'll all see soon enough how it works
Originally Posted by shiftdsm E
I was under the impression that there is no 100 flash limit. That kind of function would need to be software based, correct? and as such could be overridden. If it were a hardware limit it how would it be accomplished? All i can think of would be some sort of fuse which burns out over time, but that doesnt seem very realistic. Flash memory doesn't have a limit set to it, e.g. memory cards.
Also - anyone who reached 100 flasheds could just get a used ecu to replace his ecu
I dont think its a serious obsticle
I am more concerend about the stability of the softwear application
Originally Posted by anjapower
you obviously have much more knowledge about this stuff but this just seems very difficult to stomach. 100flash hardware limit? wth?
The chip must be good for 100 flash events with a certain range of failure rate
After that the memory starts to degrade
and yes i read the posts below by al
Its a specification of the chip maker
I'll be getting a wideband soon, I guess I should add a logger too based on your recommendations.
Originally Posted by EVOL EDO
so say you are flashing and fine tuning and say you make 10 pulls to make adjustments to the map each adjustment counts as 1 flash so after one tuning session you could be down to as little as 90 more?
So then why are you asking the question? Al already explained it.
Another point to remember is that techtom and ecutek do not reflash the whole image so say for example only 10% of the blocks are rewritten, the flash memory hardware limit is likely based off of 100 flashes of the entire image, not just parts of it so you may be able to multiply this by 10 x 10%. If in fact this new flash hardware flashes the entire image, then I would say the 100 flash range would be more accurate.
Something to think about is also the ability to read and reprogram the immobilizer unique ID code, because without it the replacement ECU would not be able to be used.
like can you flash sections or does each adjustment count as a flash. al didnt explain anything other than it is possible to go over 100 flashes but not guaranteed. ok smart guy
