IC maps?
Old May 18, 2006 | 06:32 PM
bhcevo's Avatar
IC maps?
Anyone know what the intercooler spray (IC) maps do? I'd like to change
the intercooler spraying logic on automatic mode in my 03 evo. Say, have
the IC sprayer start whenever I go WOT only. Is this possible?
Old May 18, 2006 | 07:11 PM
donour's Avatar
I'm keenly interested as well. I have no idea how the sprayer's auto mode works.
d
Old May 18, 2006 | 07:15 PM
MYEVOVIII's Avatar
Actually I believe in WOT mode in stock auto mode it does spray when it reaches a certain temp but is unable to spray non-stop due to it burning out the motor.
Old May 19, 2006 | 01:21 AM
bhcevo's Avatar
My understanding was that in auto mode it would only spray 2 seconds on 5 seconds off. Repeat.
Using manual mode I've kept it spraying for way longer than 2 sec at a time so I don't believe that burns out the motor.
Old May 19, 2006 | 01:30 AM
bhcevo's Avatar
The IC maps are as follows:
IC relay control EV ------ no idea
IC relay control vehicle speed ------ speed above/below which it wont turn on?
IC relay timer control water temp ----- Hi and Lo settings, no idea
IC relay timer control RPM ---- rpm below which it wont spray?
IC relay timer ON mode switch time --- no idea
IC relay timer Air Temp ---- below this temp it wont spray? Where is the air
temp sensor on the stock car? Do we have one? Is it after the intercooler?
IC relay timer control judgement --- Hi and Lo settings. NO friggin clue.
IC relay timer time --- On and Off fields. Specifies duty cycle?
Anyone have any insight please share.
Old May 19, 2006 | 09:59 AM
MalibuJack's Avatar
Keep in mind that the washer fluid has to EVAPORATE for it to be of any value, so spraying it constantly, or spraying then pausing, makes very little difference.. it just has to stay wet and absorb heat to evaporate..
Old May 19, 2006 | 06:43 PM
bhcevo's Avatar
The evaporation process can be very quick with a fast airflow, a large surface area and a volume of water that starts as a fine mist.
Its likely that the car operates regularly in regimes where the evaporation process is not the rate limiting step....say above 60mph on a hot, dry day with an already heat saturated intercooler.
In any case, I'd still like to know what the control logic is and how to adjust it.
Bump.
Old Sep 13, 2006 | 07:31 PM
occultworks's Avatar
Anyone learn anything new about this?
Old Sep 13, 2006 | 09:33 PM
C6C6CH3vo's Avatar
My system is inactivated due to W/M but there still remains a dormant relay energized circuit controlled manualy via switch and automatically via ECU (and allthe fun parameters on EcuFlash)
I have plans for this one, I just haven't figured what for LOL
Old Sep 14, 2006 | 07:34 AM
MalibuJack's Avatar
If its functions were more clearly documented I'd use the output for something too..
Old Sep 14, 2006 | 08:01 AM
C6C6CH3vo's Avatar
What I'm going to try when I get time is wire an indicating lamp inside to visulize it's operation when I put it into auto.
The former denso pump circuit that is controlled by a relay enrgized by ECU in respect to those mentioned parameters will be used.
My ultimate goal is to set the coolant temp parameter such that I can warned when coolant temp is slightly above operating conditions. The ECU will think that it's cooling the IC off but actually will be energizing my newly termed "coolant temp high relay" which illuminates the "engine temp slightly higher than normal" lite.
Just to help avoid head gasket problems.
Old Sep 14, 2006 | 08:41 AM
x838nwy's Avatar
would be good to know how this works. since I changed my plugs, my auto spray has been sulking and it now doesn't spray on its own anymore...
Jimmy Javelin
Mar 4, 2013 01:20 AM
PKEVO8
Jan 11, 2007 12:06 AM
scoob2evo
16
Oct 13, 2006 06:05 PM
JSYEVO
20
May 7, 2005 11:48 PM
Changy
Sep 24, 2003 09:48 PM
