adjusting the fuel maps??
Old Jun 11, 2006 | 09:48 AM
djmikeymike's Avatar
want to adjust my fuel maps and i would like some input beforei start...... my car is flashed and my high and low fuel and timeing maps are the same....... i changed to low fuel map to stock and im going to adjust my high fuel map...... right now i am using a SAFC to take out 7% fuel to get my A/Fs to 10.8....... my question is what is a good number to start with for my adjustment....... .5+/- or 1+/- adjustment on the fuel map....... i know each car is different but i was wondering how much .5+/- adjustment made on ur A/F guage...... this is my first time flashing and i dont want to goto much on my first flash.
thanks
Old Jun 11, 2006 | 12:08 PM
EVO8_PR's Avatar
what a/f ratio do you have right now?
Old Jun 11, 2006 | 12:32 PM
mchuang's Avatar
Best thing to do is check your air fuel without the afc on, since you do not need it anymore. Then flash from there in small increments til you reach your target airfuel. Me personally I would do 11.1, but I guess 10.8 is fine also
Old Jun 11, 2006 | 02:11 PM
DynoFlash's Avatar
Why dont you try one click at a time?
Note there are many variables you can adjust to correct the MAF reading - not just the fuel map and the a/f specified in the fuel map is an arbitray number unrelated to the actual a/f.
Old Jun 11, 2006 | 04:08 PM
yes the plain is to remove the SAFC..... without the SAFC my A/Fs are in the high 9s.......... and i also understand the numbers in the fuel maps are not the actual A/Fs...... so my question is how much to start adjusting by...... .1-/+ or .5-/= or 1.0-/+
Old Jun 12, 2006 | 05:56 AM
ScrappyJack's Avatar
I would start out making adjustments in 0.1 unit increments until you have a feel for it.
Old Jun 12, 2006 | 05:58 AM
MalibuJack's Avatar
I would definitely stay away from large jumps as said before.. Unless the car is running really rich where your certain a large jump won't cause the car to run too lean. This is something you get the hang of..
Old Jun 16, 2006 | 02:15 PM
all right i changed both the low fuel and timing maps to stock and adjusted my high fuel map by +.5 and +.3......... im just waiting for EVOscan to flash it........
Old Jun 16, 2006 | 04:20 PM
AlwaysinBoost's Avatar
mike, you can use my a pocketlogger to watch your timing since you already have the lc-1/xd-16 combo. those two tools are all I've used so far to make adjustments on my car. you just have to make very small adjustments at a time.
Old Jun 17, 2006 | 02:07 PM
where is boostville??? any where near reading?
PIE-R
Dec 21, 2019 08:14 PM
Colt4g63
Dec 1, 2007 07:02 AM
Mellon Racing
68
Oct 25, 2007 09:06 AM
nj1266
Mar 5, 2007 07:52 PM
anjapower
Jun 14, 2006 08:47 PM
