Re: adjusting fuel map
Old Jun 13, 2006 | 10:34 AM
anjapower's Avatar
I want to richen up my high octane fuel map. I know the values in there are arbitrary as far as target A/F is concerned but wondering if someone can give me tips on how to change the values.
I want to richen up my A/F by .5. Would it be advisable to change all the values in the boost tables to X-0.5?
Or should I increase by 1-2% fuel in all the boost columns until I'm running the desired A/F?
Old Jun 13, 2006 | 11:20 AM
ScrappyJack's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=205784
Old Jun 13, 2006 | 01:19 PM
anjapower's Avatar
thanks for the link...although I guess my question is pretty much common sense.
To add on to it...when richening up the A/F under boost, should I richen all the columns for say 3000+ RPM and from 0psi and up?
Going too rich at spoolup will hinder fast spoolup so I'd like to know what columns and RPM range I should concentrate on for A/F tuning under WOT.
Old Jun 13, 2006 | 03:11 PM
djmikeymike's Avatar
im starting at column 140 @ 3500 and working down and to the right....... but i have a mailin flash that im starting from
i know the values in the map are not the actual A/Fs...... but i think you where asking the same question i was trying to.......... if you adjust a cell by 1.0 will that change 1.0 on your A/F gauge........ say your A/F gauge reads 10.0 and the corresponding cell on the map says 8.0 and you adjust that cell to 9.0 will that change the reading on your A/F gauge to 11.0............
Old Jun 14, 2006 | 06:55 PM
thatsMR2u's Avatar
anja confirm with your wideband at boost levels, i realized i had to lean mine out at around 14 psi and up so i started at the 200 column around 3500 rpms and it worked great
Old Jun 14, 2006 | 08:47 PM
TTP Engineering's Avatar
This is a pretty close formula. I would feel comfortable advising you that would be ok as long as you have a wideband to monitor with an acceptable sample and display rate.
nicolassabra
Jun 7, 2013 06:01 PM
Dynojet_Research
Mar 7, 2010 09:40 AM
maikonkun
27
Aug 12, 2004 07:56 AM
antzlim
Apr 18, 2004 01:03 AM
