ECU Flash working with SAFC
you still need to scale the injectors for your application... but you base tune the car with the S-afc zeroed out, then you map the timing and fuel in adjacent cells.. Now both boost and AFC settings will bump things where you want it.. This is a pretty common technique, I'm using it with an ECU+ but I have it completely zeroed out right now.
so sero the SAFC, what my timing table should look like ??. i knowest at 7000rpm 260 load my timing is only like 14 on the table, i was wondering if i can bump a little timing up. can someone give an example thanks.
