Injector scaling and latecy for different injectors.
Old Mar 12, 2008 | 07:14 PM
  #376
TTP Engineering's Avatar
FIC modifies many Rochester units.
Old Mar 12, 2008 | 07:15 PM
  #377
RazorLab's Avatar
Originally Posted by TTP Engineering
That should be easy since the PTE is a FIC with a sticker on it.
I used to think that too but they use different latencies and scales to work well. Probably custom modded.
  #378
JohnBradley's Avatar
FIC rates their injectors funny.
Take for instance the 1050. It is actually a 105# per minute injector. 105 x 10.5(conversion)=1102cc which matches the balance chart perfectly.
750=787
850=892
etc.
I am all about helping, but some things I cant just hand out. I will tell you though that 914 worked well for the scaling on the 1050's.
FIC1000s are 860 and it seems to work well. Latency looked something like this (again for the 1000 not 1050)
3.312
1.68
1.344
1.152
0.84
0.504
0.24
Old Mar 12, 2008 | 07:19 PM
  #379
bigric09's Avatar
thats all i need i think JB... im close just playing around with those numbers
Old Mar 12, 2008 | 08:20 PM
  #380
fastrob691's Avatar
What company does AMS use? I got their 780s and wound up at 739 which works about right for the FIC?
750=787
850=892
etc.
3.312
1.68
1.344
1.152
0.84
0.504
0.24
Old Mar 12, 2008 | 08:35 PM
  #381
FIC typically ACTUALLY FLOWS what they are rated.
Old Mar 12, 2008 | 08:40 PM
  #382
Most of my 780's end up in mid to high 600's. I am not sure what company they use but I believe it had been PTE (precision).
Scaling injectors is kind of like women. There are alot of them and our goal is to get the one we want. You dont always use the same tactics though even with the same woman. Throw all the different types you are bound to encounter into the mix and sooner or later you realise its the journey as much as the destination.
In otherwords, two people will not have the same scaling or latency even for the same injector. Heck I put a set of Stock 560's in a honda and in Emange I entered the size and latency as listed in ECUflash. Guess what? Like all hondas nothing you "know" helps. Ended up having to go to totally different scaling and values to get it cooperate.
Edit-I think I misunderstood the question based on Scotts response. I thought we were talking about scaling not flow rating. I have never seen a balance chart for FIC's flow less than they are rated but they almost always flow the equivalent of their lb/min rating as it had been explained to me.
Old Mar 13, 2008 | 08:48 AM
  #383
Mad_SB's Avatar
Agree with the above, pte 780 usually ends up around 636 - 650 scale, I think the injectors buschur sells as 680's are actually pte 780's but I'm not 100% sue about that.
Old Mar 13, 2008 | 11:56 AM
  #384
bostonhatcher's Avatar
You guys are making injector scaling way too hard. Most injectors are rated at 43.5 psi fuel pressure. A fuel pressure regulator will allow that much pressure at 0 psi from the intake manifold. At idle, there is some vacuum which will take some fuel pressure away.
So read what your fuel pressure says at idle, let's say it's 38 psi.
38psi/43.5psi = 87.35%
Take 12.65% out of your advertised injector size and that's your injector scaling. Of course you will still have to make small changes after logging your fuel trims but this will get you much closer than guessing.
Injector latencies would have to be tested in an isolated environment, not on a car. Refer to AEM's latency tables that they have defined. The link is under "how to tune an evo" thread and it's in the stickies on this subforum.
Old Mar 13, 2008 | 12:26 PM
  #385
steadly2004's Avatar
I never thought about it like that! very good observation
Old Mar 13, 2008 | 12:42 PM
  #386
PVD04's Avatar
Unfortunately that doesn't really explain any of it. With vacuum in your intake manifold you still have a 43.5 psi pressure differential across the injector. The reason your fuel pressure drops is to maintain that 43.5 psi, if it did not you would have an effective fuel pressure of 48.5 psi at idle and 23.5 at 20 psi.
-Paul
Old Mar 13, 2008 | 02:22 PM
  #387
doesn't the fuel pressure raise with boost?
I do get that vacuum is still a factor, but less of a factor when fuel psi raises with boost
Old Mar 13, 2008 | 02:34 PM
  #388
-Paul
Ok so why do you disconnect your vacuum line on an adjustable fuel pressure regulator when setting your base fuel pressure? Vacuum will bring down fuel pressure at a 1:1 ratio.
Old Mar 13, 2008 | 02:43 PM
  #389
evovin's Avatar
Are they harder to scale compare to PTE?
Old Mar 13, 2008 | 02:57 PM
  #390
-Paul
Where's your theory on why every single injector that's rated for 43.5 psi has to be scaled down 10-15%? All I see is a bunch of talk about "pressure differential across the injector" LOL.
Don't post stupid theories about boost making fuel pressure go down either. In fact, don't post anything but questions because you are lost.
