Injector scaling and latecy for different injectors.
Old Apr 20, 2008 | 04:39 PM
  #436
dan l's Avatar
We are probably misunderstanding eachother. It will also idle bad if too rich, it'll be blubbery. Lean and it sounds like it has huge cams and will stall easily.
Old Apr 22, 2008 | 01:48 AM
  #437
JoeBee's Avatar
Originally Posted by JoeBee
Can anybody give me a tipp which injector scaling to use for
Precision 780 er with E85 ?
Have nobody done this? Should I simply add 30% to the scaling of pump?
So 696 for pump -> 696*0.7= 487 for E85
Old Apr 27, 2008 | 10:41 PM
  #438
4kinboost's Avatar
Anyone dialed in MSD 96lbs injectors?
Old Apr 28, 2008 | 06:01 PM
  #439
Ralph's Avatar
Also going to be in need of PTE1000CC's..
Old Apr 29, 2008 | 05:48 AM
  #440
TeStUdO's Avatar
Originally Posted by TeStUdO
This is my scaling with my PTE 1000cc's
Scaling: 725
Latency:
7v 9.4v 11.7v 14v 16.4v 18.6v
2.186 1.281 0.771 0.458 0.283 0.172
This is my post from the previous page.
Old Apr 29, 2008 | 07:26 AM
  #441
Ralph's Avatar
Will be trying them out this weekend, thanks .
Old May 3, 2008 | 08:16 AM
  #442
mrfred's Avatar
Found this page that lists latency values for a bunch of different injectors. Don't know how accurate the values are, but could be a good starting point.
http://injector-rehab.com/kbse/lag.htm
Old May 3, 2008 | 08:27 AM
  #443
sub7's Avatar
Good stuff! Thanks for sharing
Old Jun 15, 2008 | 05:56 PM
  #444
PeteyTurbo's Avatar
Originally Posted by nj1266
Here is what I used on PTE 880s that I scaled yesterday:
Scaling 731
Latency
3.312
2.184
1.32
0.96
0.696
0.408
0.288
The car was an Evo 9 with all the bolt-ons and HKS cams. Trims maxed out at -4 for the mid and +2.6 for the low.
Treat them as a starting point only. I have noticed that PTE injectors are harder to scale than the Densos and RCs that I have scaled.
I used this today when I installed my PTE 880's..Works like a charm and almost dead on from the start.
mid +5
low -3
I got them down to -1 +3 now..Runs like stock and starts right up!
THANK YOU NJ1266!
Old Jun 18, 2008 | 01:56 PM
  #445
DvlInDskyz's Avatar
Threw in my pte780's and used the scaling 696 and values in post # 136 and have great idle and drivability. I'll have to log some to find out if it needs to be tweeked some, but a great thread overall! Thanks to all!
Old Jun 25, 2008 | 06:43 PM
  #446
cossie1's Avatar
I run PTE 680cc
Scaled as 650cc
Latency
3.312
2.184
1.416
0.960
0.696
0.480
0.360
Fuel Trims are:
Low 3.6
Med 0.9
High 0.9
Old Jul 9, 2008 | 10:44 PM
  #447
Inprogress's Avatar
FINALLY MY FUEL TRIMS CHANGED!!!!!!
In evoscan v2.4 I'm getting -1.8 (stayed there for 3minutes) and then after a while it went to -3.4 and stayed there for over 4 minutes at which point i concluded the log.
I logged at idle for just over 15 minutes. Are these trims for LTFT-lo ok?
Old Jul 10, 2008 | 01:51 PM
  #448
Inprogress's Avatar
Any input?
Old Jul 10, 2008 | 03:50 PM
  #449
kkarim's Avatar
any one got scaling and latencies for Forced Performance (Delphi) 950cc injectors?
Old Jul 10, 2008 | 08:10 PM
  #450
oldevodude's Avatar
What is the mid reading? The mid will post something after about 16 minutes of what ecu calls cruise or light throttle driving. Minus 3.4 is not bad. Now you can try logging with Mitsulogger as this is what most seem to trust and use for trims.
