Injector scaling and latecy for different injectors.
Old Mar 15, 2010 | 10:42 PM
  #871
mrfred's Avatar
Originally Posted by NCarrillo
Been at this for a while now and some help would be appreciated. Running Precision Buschur Spec 1000CC injectors. Current Values:
Scaling: 790
4.6875 3.312
7.03125 1.680
9.375 1.464
11.7188 0.96
14.0625 0.768
16.4062 0.48
18.6768 0.36
LTFT LOW: 1.4735
LTFT MID: -9.9003
Not sure what to do at this point. Would really appreciate some help. Thanks in advance!
If these trims were generated with at least an hour of stop and go driving, then I suggest increasing the scaling by 10%, i.e., set the injector scaling value to the value closest to 870. Then increase all the latency values by 0.040. Let us know what trims you get after at least an hour of stop and go driving with the revised settings.
Old Mar 17, 2010 | 10:02 AM
  #872
NCarrillo's Avatar
Ok, so I got a chance to log them at different setting today. Here is what I got:
Scaling:860
4.6875 3.360
7.03125 1.728
9.375 1.512
11.7188 1.008
14.0625 0.816
16.4062 0.528
18.6768 0.408
LTFT LOW: 0.2
LTFT MID: -5.5
Old Mar 17, 2010 | 11:36 AM
  #873
mrfred's Avatar
Scaling:860
4.6875 3.360
7.03125 1.728
9.375 1.512
11.7188 1.008
14.0625 0.816
16.4062 0.528
18.6768 0.408
LTFT LOW: 0.2
LTFT MID: -5.5
Almost there. Increase scaling to value closest to but not less than 903, and increase all latency values by 0.020.
Old Mar 17, 2010 | 04:26 PM
  #874
NCarrillo's Avatar
Ok, so I got a chance to log them again at different setting. Here is what I got:
Scaling: 914
4.6875 3.384
7.03125 1.752
9.375 1.560
11.7188 1.032
14.0625 0.840
16.4062 0.552
18.6768 0.456
LTFT LOW: 5.98
LTFT MID: 2.6
Old Mar 18, 2010 | 01:15 AM
  #875
mrfred's Avatar
See next post.
Old Mar 18, 2010 | 01:16 AM
  #876
mrfred's Avatar
Scaling: 914
4.6875 3.384
7.03125 1.752
9.375 1.560
11.7188 1.032
14.0625 0.840
16.4062 0.552
18.6768 0.456
LTFT LOW: 5.98
LTFT MID: 2.6
Increase all latencies by 0.050.
Old Mar 18, 2010 | 01:23 AM
  #877
And's Avatar
And
just a question, can you damage the injectors if you over ms them per voltage or will you just add too much fuel and blow the spark out? take this example, if the injectors are the same what would be the findings from running either voltage?
V ms (1) ms (2)
4.6875 3.312 4.752
7.03125 1.68 2.352
9.375 1.032 1.848
11.7188 0.672 1.32
14.0625 0.432 0.912
16.4062 0.264 0.696
18.6768 0.144 0.408
thanks
Andy
Old Mar 18, 2010 | 02:16 AM
  #878
mrfred's Avatar
V ms (1) ms (2)
4.6875 3.312 4.752
7.03125 1.68 2.352
9.375 1.032 1.848
11.7188 0.672 1.32
14.0625 0.432 0.912
16.4062 0.264 0.696
18.6768 0.144 0.408
thanks
Andy
Won't damage the injectors... car will just run like crap with bad latency and/or scaling values.
Old Mar 18, 2010 | 10:11 AM
  #879
EVIL_EV0's Avatar
I have my rear O2 disabled and removed. Therefore there is no way for me to read fuel trims. Does the ECU still figure out what to do with a rich/lean condition even though the trims are not visible to me?
Is there a clever way to read fuel trims without going back in and turning the sensor back on?
As of now I have no way to read fuel trims unless I turn the sensor back on. However my wideband says my idle and cruise is 14.2 instead of 14.7. In this situation do you change injector scaling or latencies? I suspect the ECU has pulled all it can from the AFR.
Old Mar 18, 2010 | 10:18 AM
  #880
travman's Avatar
deleted
I stand corrected
Old Mar 18, 2010 | 10:43 AM
  #881
NCarrillo's Avatar
Ok, so I got a chance to log them again at different setting it was to much when added .050 trim was 0 for low and -8 for mid. Here is what I got when added 0.020
Scaling: 914
4.6875 3.408
7.03125 1.776
9.375 1.584
11.7188 1.056
14.0625 0.864
16.4062 0.576
18.6768 0.480
LTFT LOW: 0
LTFT MID: -4.9
Old Mar 18, 2010 | 11:16 AM
  #882
mrfred's Avatar
Scaling: 914
4.6875 3.408
7.03125 1.776
9.375 1.584
11.7188 1.056
14.0625 0.864
16.4062 0.576
18.6768 0.480
LTFT LOW: 0
LTFT MID: -4.9
That's a bit strange because the latency value should have a much stronger affect on the LTFT low. Now that you're getting close, I think you need a few more drive cycles to get a better feel for the trims before further changes are made. Report back the fuel trims after driving for a few days with the current settings.
Old Mar 18, 2010 | 05:29 PM
  #883
4DOORGALLOR's Avatar
Originally Posted by travman
rear O2 has nothing to do with reading fuel trims......
I thought if the rear o2 was disabled your trims would be as well. Has something to do with the ECU and not the O2 itself.
Old Mar 18, 2010 | 07:31 PM
  #884
bigric09's Avatar
eh... try again
Old Mar 18, 2010 | 07:33 PM
  #885
Fast_Freddie's Avatar
Veteran: Navy
If the rear o2 is disabled via periphery, the fuel trims will not register...
