Injector scaling and latecy for different injectors.
Old Jan 11, 2011 | 11:25 PM
  #931
Dragracer187's Avatar
Originally Posted by tephra
well that scaling is about right.
so as long as your trims are about right then you know the latencies are about right..
what other mods u got? maybe the intake needs to be scaled in?
low trim is within 5%, mid trim is -9%, but have a problem with evoscan not updating it when logging, but I downloaded evoscan 2.8, will try again today.
Intake is stock piping with a fujita filter.
Other mods:
S2 cams
evo ix turbo
TBE
ID1000's
ETS FMIC
I checked for boost leaks. No leaks. Maf scaling is stock. Map values for afr are 7.4 between 4000 and 6000 rpm. Car could not get richer then 12.8. After 6000 it goes richer.
Old Jan 11, 2011 | 11:45 PM
  #932
JohnBradley's Avatar
Fuel pump issue possibly. The last ID1000 car I did scaling was 790 so it should be in the ball park.
It was an SD car so latencies dont always jive, here are the ones I had FWIW-
3.312
2.112
1.776
1.152
0.864
0.504
0.384
Old Jan 12, 2011 | 12:26 AM
  #933
tephra's Avatar
Other mods:
S2 cams
evo ix turbo
TBE
ID1000's
ETS FMIC
I reckon get your trims in check a bit more.. -/+ 5% is ok....
Old Jan 12, 2011 | 02:15 PM
  #934
I checked fuel trims low again, they were now within 1%, but fuel trim mid was at -12.5% and never changed during a 20 min drive. I then tried these settings that I also found in the injector latency merged topic:
Scaling 812
3.816
3.144
1.944
1.392
0.984
0.72
0.504
Now I did another 20 min cruise. And at the end finally I saw a value changing for mid trims. It changed from -12.5 to -8.59. I also tested my low trims these went from within 1% to 4.6%.
I think I will try both low and mid trims to cycle a few more time to see where it will go.
Old Feb 17, 2011 | 07:38 AM
  #935
Creamo3's Avatar
Does anyone have scaling/latencies for Deatchwerks 1600cc injectors? I'm trying to help a local guy out that needs to get emissions tested and go back on stock ECU from AEM setup. He's currently on pump 93 which should make things interesting, not even sure these things will idle on stock ECU. Let me know if you guys have any suggestions; only other option I told him we could do is to swap back to stock injectors for emissions/ODB-II scan.
Old May 25, 2011 | 09:10 PM
  #936
nonschlont's Avatar
PTE = Precision
I have (what most likely will be a dumb) question/'s...
Are PTE and Precision inj's. the same???
I have a buddy (evo IX) that wants me to set up a dual map w/ e-85, precision 1200's, but havent found anything for these inj. (yes I have searched)... I have found a few scaling/latencies for "PTE 1200's"... Which is why Im asking my question...
heres what Ive found for the PTE's:
(pump gas)
JB's scaling 1044
3.312
2.184
2.088
1.296
0.792
0.72
0.48
E85 Scaling- 680
the same as above except
11.72- 1.344
14.06- .864 (based on his RC 1200's)
scaling 886
3.192
2.208
1.512
1.056
0.696
0.504
0.288
(e-85)
Scaling 750 / 770
5.280
3.000
1.776
1.152
.864
.528
.312
Im thinkin I'll start w/ JB's scaling/latencies as my starting point.?.?.
TIA
Old May 29, 2011 | 11:50 PM
  #937
nonschlont's Avatar
well heres what I ended up w/ today on an evo ix. (stock motor/cams)
precision (PTE) 1200's...
pump (91)
860
3.312
2.208
1.512
1.080
0.744
0.504
0.288
(E-85)
scaling
622
Old Jun 23, 2011 | 12:05 AM
  #938
Danieln's Avatar
Hi guys,
Can someone help me with injector scaling on E85 for Sard 800cc (LATENCY" for Sard 800c/min injecors is 1.6ms)....
I assume that E85 will have a scaling with 30% lower than Gasoline....
Thanks
Old Jun 23, 2011 | 03:52 AM
  #939
todd6027's Avatar
Originally Posted by Danieln
Hi guys,
Thanks
hi daniel,, i wouldnt use anything less then 1000cc for e85
Old Jun 23, 2011 | 04:33 AM
  #940
Danieln's Avatar
Hi mate,
I have bought those injectors for pump gas use but we face a urgent issue and I want to install them on a GruppeN evo 9 (without 33mm restrictor)....
With 33mm restrictor..... E85 can be used without any problem since the cars are not running more than 5500 RPM`s.....
I need a starting point for those 800cc injectors if possible.....(latency for gasoline and E85).
I found the scaling for 780cc injectors on pump gas.....thanks to Jon...
Maybe this can be close for 800cc scaling....
Now I look for E85 scaling
Regards
Old Jul 23, 2011 | 08:40 PM
  #941
INEVOIX's Avatar
Anyone have the settings for FIC 2150 (high Z). Obviously the resistor pack has been removed.
E85
Thanks in advance
Old Jul 25, 2011 | 10:49 AM
  #942
GottaZtt's Avatar
hey guys, i have an evo 7 and i got ID 725cc injectors and i cant seem to find much info on here.
would appreciate the help. using Ecuflash
scaling and deadtimes needed
Old Jul 26, 2011 | 12:57 AM
  #943
merlin.oz's Avatar
for FIC_2150
scaling E85=1624
3.000
1.488
0.936
0.672
0.528
0.408
0.360
Old Jul 27, 2011 | 02:18 PM
  #944
GottaZtt's Avatar
anyone?!?!?!
Old Sep 15, 2011 | 09:01 AM
  #945
vgknight's Avatar
Hey guys I am trying to Scale a set of PTE 1600cc for 91 and e85 for dual map.
Any info would be appreciated
