Injector scaling and latecy for different injectors.
Old Mar 18, 2010 | 07:43 PM
  #886
EVIL_EV0's Avatar
Okay... then what is the hack to disable the heater circuit and not scram the fuel trims?
Old Mar 19, 2010 | 06:09 PM
  #887
Fast_Freddie's Avatar
Veteran: Navy
That is if you want to remove the rear o2 completely
Old Mar 19, 2010 | 06:18 PM
  #888
nothere's Avatar
there is a simulated rear O2 that MRFRED made. iirc I am using it and I do have usable 02 readings.
I think...
Old Mar 19, 2010 | 08:48 PM
  #889
EVIL_EV0's Avatar
Exactly. I don't even have a rear O2 in my possession. No CEL. NO fuel trims.
Am I expected to turn the senor back on via checkbox in the ROM and drive around with a CEL?
Who has their sensor turned off but still has fuel trims. Can you post the code you used to turn the sensor off?
Old Mar 20, 2010 | 05:04 AM
  #890
bigric09's Avatar
i leave mine on... and just use the rear O2 simulator option and have the CEL turned off for the no cat code it throws.
Old Mar 20, 2010 | 01:19 PM
  #891
logic's Avatar
EVIL_EVO: See this thread for the correct way to disable the rear O2 heater CEL. See this thread for passing OBD-II (emissions) inspections.
I don't have a rear O2 sensor physically installed in the car (and don't have a cat, either), don't throw any codes, and have passed emissions testing here in Illinois with those two patches along with the rear O2 simulation code that comes along with tephra's ROM.
Old Mar 21, 2010 | 08:20 PM
  #892
EVIL_EV0's Avatar
Thanks..... and your trims work?
Old Mar 22, 2010 | 12:58 AM
  #893
norcalSRTrida's Avatar
anyone have any luck w/ the bosch/PTE 1600s? got a friend that bought a set so looking to help him out..
Old Mar 22, 2010 | 07:41 AM
  #894
logic's Avatar
Yep.
Old Mar 25, 2010 | 06:05 PM
  #895
NCarrillo's Avatar
Ok new trims are 3.8 for low and -2.8 for mid. Every time I change latency value seems to have a strong effect on mid.Scaled at 1008. Are the values considered Scaled MrFred? Think it's the closest I've gotten after a week. I can't tell you enough how I appreciated you help sir! Thank You!
Old Mar 25, 2010 | 06:27 PM
  #896
mrfred's Avatar
Glad I could be of help. You're trims are very pretty good in most people's book. I'd probably fiddle a bit more myself. Latency should have some effect on the mid trim when the scaling is right on. Its just that it should affect the low more than the mid. If you are seeing a consistently greater effect on mid with a latency change, then you might want to make sure that you don't have the low and mid trims mixed up.
Old Mar 25, 2010 | 08:25 PM
  #897
NCarrillo's Avatar
Idles pretty good when in closed loop but after I shut if off and restart the wideband readings are super lean. Know of any cause?
Old Mar 25, 2010 | 08:42 PM
  #898
NCarrillo's Avatar
Was reading somewhere about pulling pull resistor box. Is that something that needs to be done when installing bigger injectors?
Old Mar 25, 2010 | 10:46 PM
  #899
mrfred's Avatar
Removing the resistor box is only for people who have installed high impedance injectors (pretty much only Bosch).
If it warm starts up and idles fine, I wouldn't worry about an initial lean reading. What wideband are you using?
Old Mar 26, 2010 | 10:10 PM
  #900
NCarrillo's Avatar
AEM UEGO. It doesn't warm up start fine. It's always seems to run lean on intial start up, no matter what.
