Injector scaling and latecy for different injectors.
Old Jun 16, 2007 | 07:01 AM
  #181
Oracle1's Avatar
Volts MS
4.69 3.576
7.03 1.944
9.38 1.296
11.72 0.984
14.06 0.768
16.41 0.624
18.68 0.504
Old Jun 17, 2007 | 03:33 PM
  #182
Oracle1's Avatar
What Injector scaling would you recommend?
Originally Posted by Ivan_C
Here are the injector battery comps that I have scaled via numbers only. I pulled the data from the AEMPro software. These should be good starting numbers.
Let me know what you think. I've attached the xls file.
Ivan
HTML Code:
Note: PTE780/880 calculated from 680/1000
Offset and scaled to match factory ECU
	            7v	 9.4v  11.7v	14v	16.4v	 18.6v
Stock	          1.680 1.032   0.672   0.432   0.264   0.144
PTE1000	          2.186	1.281	0.771	0.458	0.283	0.172
PTE880	          2.186	1.325	0.833	0.534	0.351	0.231
PTE780	          2.186	1.369	0.895	0.610	0.419	0.290
PTE680	          2.186	1.413	0.957	0.687	0.486	0.349
MSD750	          2.186	1.302	0.781	0.452	0.256	0.126
RC720/900	  2.186	1.518	1.032	0.694	0.443	0.268
RC1000	          2.023	1.079	0.641	0.367	0.181	0.049
RC1200	          2.186	2.085	1.581	1.060	0.713	0.471
Holey788	  1.903	0.952	0.573	0.353	0.193	0.093
HKS1000	          2.109	1.189	0.812	0.583	0.382	0.248
FIC650	          2.100	1.071	0.633	0.353	0.175	0.044
FIC850            2.031	0.971	0.591	0.334	0.195	0.106
FIC950	          2.186	1.220	0.706	0.425	0.274	0.175
Old Jun 22, 2007 | 04:19 PM
  #183
UCB's Avatar
UCB
Originally Posted by Oracle1
665
Volts MS
4.69 3.576
7.03 1.944
9.38 1.296
11.72 0.984
14.06 0.768
16.41 0.624
18.68 0.504
This is for the RC750s?
Old Jun 23, 2007 | 07:53 AM
  #184
mitsu matt's Avatar
I have a question regarding tuning battery voltage latencies when running larger cams. I am running Denso 660 injectors that flow tested out at 780/780/820/810.
Getting long term low to match with long term mid has been quite a chore. I have dialed in the mid trim using injector scaling while trying to get low trim to match up with latency adjustments. At this point I am at almost .800ms @ 14 volts which seems to be a lot of latency offset for injectors that I would think shouldn't be that far off of stock.
I am curious if the overlap from my 280's at idle are making it impossible to tune the low fuel trim properly, and if so what point do I just call it good? Also, I am running an open element AEM airfilter on a stock snorkel, and I am starting to wonder if I should go back to the stock airbox for tuning in the latency.
Any advice is greatly appreciated.
Old Jun 23, 2007 | 08:06 AM
  #185
nothere's Avatar
I have the same injectors and they seem to be haunted. As you, the low trim is way high if I get the the mid trim on.
I am running small cams, but have a ported head and valves which I thought might be involved.
before I go to far on the latencies I am going to change the fuel map in the idle area.
sorry no help on your specific question about big cams.
so far I've tried scales from 607 down to 522 and in every case the car has behaved well and really didn't need to be refined. But it bugs me so I keep at it.
One thing I did not know is it takes a relatively long time for the trims to move and once they move are affected each time the car goes through warm up.
Old Jun 23, 2007 | 11:31 AM
  #186
Oracle1's Avatar
Yes!
Try @14v = 744. Everything else the same.
Old Jun 23, 2007 | 12:02 PM
  #187
RazorLab's Avatar
For Denso 660cc try this and see if they work well in your application:
6.12
3.12
1.992
1.272
0.744
0.648
0.408
Scaling: 636
For denso 720cc I use around .888 for 14v with success on most Evo's so you being close to .8XX isn't unheard of since the 660's flow almost as much as the 720's.
Old Jun 23, 2007 | 09:21 PM
  #188
nothere's Avatar
razorlab, re 660
would those latencies be custom for big cams? I have input your 636.
can you tell me how the extreme voltage numbers work? I doubt the car ever sees anything other than 10 to 15 volts. So the inputs are trends or do they have another meaning.
update, in my case razorlab's suggestion has dialed in pretty close.
Old Jun 28, 2007 | 11:15 AM
  #189
UCB's Avatar
UCB
Car seems to be running rich, here is my idle log, any issues you all see? I'm still not fully understanding this +/1 stft stuff
File Type: txt
Old Jun 28, 2007 | 11:24 AM
  #190
RazorLab's Avatar
Glad it helped!
Old Jun 28, 2007 | 11:33 AM
  #191
l2r99gst's Avatar
It looks like your fuel trims are maxed out, but I'm not sure with that wacky scale that Evoscan comes with, by default.
To save yourself headaches with fuel trims, go and find the correct forumlas (and request IDs) for them. I'm pretty sure Mitsulogger has the correct formulas. If you can't find them, I will post them later.
When you have the formulas correct, it will tell you the percentage of fuel the ECU is adding or taking away. So, for example your Lo trim may be -12%, meannig that the ECU is taknig away 12% to try to maintain a stoicj 14.7:1.
Anyway, even though I'm not familiar with this scale (where 100 is really 0), it looks like your injector scaling and/or latency are qutie a bit off.
Eric
Old Jun 28, 2007 | 11:55 AM
  #192
RazorLab's Avatar
Yes, mitsulogger is better to monitor fuel trims with. Evoscan is wonky that way.
Old Jun 28, 2007 | 12:21 PM
  #193
UCB's Avatar
UCB
Thanks, will log it with mitsulogger instead
The injectors are RC750s, scaled to 665, basically the same latency values shown in that chart from AEM for the RC720/900 row
Old Jun 28, 2007 | 12:23 PM
  #194
TouringBubble's Avatar
Eric
I would love to modify EvoScan to monitor fuel trims like Mitsulogger does. The base 100 thing throws me off a little as well. If you don't mind, could you post the code? I have not been able to find it.
Old Jun 28, 2007 | 12:51 PM
  #195
l2r99gst's Avatar
Here is how the lines should look in Mitsulogger....you may need to change it for the syntax that EvoScan wants:
<Request LogReference="LTFT_Low" RequestID="0C" Eval="int(.1961*x)-25" Unit="%" Logged="y" Response="2"/>
<Request LogReference="LTFT_Middle" RequestID="0D" Eval="int(.1961*x)-25" Unit="%" Logged="y" Response="2"/>
<Request LogReference="LTFT_High" RequestID="0E" Eval="int(.1961*x)-25" Unit="%" Logged="y" Response="2"/>
<Request LogReference="STFT" RequestID="0F" Eval="int(.1961*x)-25" Unit="%" Logged="y" Response="2"/>
LTFT is short for Long Term Fuel Trim. STFT is short for Short Term Fuel Trim.
This formula will tell you the exact percentages of fuel that the ECU is subtracting or adding to reach a stocih 14.7:1.
So, +10 means 10 % of fuel is being added...-10 means the ECU is removing 10% of fuel. This is MUCH easier when trying to calculate the correct scaling and latencies for your injectors.
Eric
