First datalogs, please comment
Old Jul 10, 2006, 10:03 PM
  #76
mchuang's Avatar
Originally Posted by dudical26
I got knock today on my bone stock IX running 93
Code:
RPM	TPS	KnockSum	TimingAdv
2062.5	100	0	15
2218.75	100	0	16
2343.75	100	0	17
2500	100	0	18
2625	100	0	18
2781.25	100	0	18
2937.5	100	0	17
3125	100	0	15
3312.5	100	0	12
3500	100	0	10
3687.5	100	0	8
3906.25	100	0	6
4187.5	100	0	3
4437.5	100	0	3
4687.5	100	2	4
5000	100	1	7
5281.25	100	0	9
5593.75	100	0	10
5843.75	100	0	11
6125	100	0	12
6343.75	90.5	0	14
6375	12.9	0	36
6093.75	12.9   0	23
6000	100	0	13
5031.25	100	0	7
4718.75	100	0	8
5250	100	2	3
5062.5	100	2	5
5406.25	100	1	7
5468.75	100	0	10
5625	100	0	10
5781.25	100	0	12
5906.25	100	0	12
6062.5	100	0	12
6187.5	100	0	13
6312.5	100	0	15
6437.5	100	0	15
6625	100	0	17
7656.25	100	0	19
7625	100	0	24
5906.25	100	0	10
4750	100	0	6
5343.75	100	0	6
5218.75	100	0	10
5218.75	100	0	10
5437.5	100	0	10
5468.75	100	0	11
See that is what I am refering to, mitsu is playing it safe which is understandable, since they are producing a turbocharged production car in which many things can easily go wrong and cause the car to blow up.
Old Jul 11, 2006, 12:37 AM
  #77
jcsbanks's Avatar
I wouldn't let anyone near my knock filters or timing map without someone doing realtime knock monitoring, not just checking the plugs afterwards.
This sort of behaviour of sporadic minor knock counts/knock correction is typical on a turbocharged engine IMHO. I believe it is near enough that I don't need to fiddle with the filters on my car for road use with a variance of fuel quality tank to tank, and different EGTs, intake temps etc. You can never control all the variables run to run. This is exactly why I like good knock control because it picks up this minor stuff and generally prevents it becoming a problem.
Having stopped for 30 mins, what were your post intercooler temperatures like before you gunned it again - I find it can take several miles for them to normalise again after being at say 60C after sitting for a while.
Old Jul 11, 2006, 02:29 AM
  #78
mchuang's Avatar
There were turbo cars out before this type of knock protection, so it is no big deal. This is a streetcar and variables do change and any tuner in his right mind knows not to tune a streetcar on the edge. I trust my tuner enough to where if he weakin the knock protection somewhat that my car will still be tuned safely. He tuned my 2 other turbo cars without knock protection 1 on AEM and the other on an afc with vpc and they never had any problems. I never said I was gonna turn it off anyways, I just said I was going to make it less sensitive. Anyways gotta pay to play, if you wanna go fast.
Old Jul 11, 2006, 04:46 AM
  #79
jcsbanks's Avatar
Older turbo cars didn't run on pump fuel at 20 PSI on 8.8:1 compression ratio and make amongst the highest specific output of a production engine though.
I find from listening to the engine through det cans that a degree of timing is enough to go from no real noise to obvious detonation - it avalanches. Since we only have 1 degree timing resolution on our 8 bit maps it will be interesting to hear what gains you get.
Old Jul 11, 2006, 04:58 AM
  #80
jcsbanks's Avatar
Originally Posted by mchuang
Haha you think that is extraordinary, hondas do it all the time. I see 2.0 liter hondas making 400hp on 11psi. I know it aint awd but still. I myself made 351 on 9psi 60-1 in a 1.8 gsr. comp 9:1. I mean his numbers maybe be slightly inflated but it is definetly possible.
You'll note I was talking about torque, not power.
Hondas doing 120 or so BHP/liter/bar is only what they do stock. Doing > 100 lbft/liter/bar is a completely different story altogether.
Old Jul 11, 2006, 05:10 AM
  #81
dudical26's Avatar
With my stock map getting a little knock like that, is it safe for me to upload the new flashed map I got from Al. The new map has significantly higher timing values.
Maybe I will just wait till I can fill up my tank at a different station and see if the knock goes away on the stock map.
Old Jul 11, 2006, 07:12 AM
  #82
travman's Avatar
your knock is fine?.....that 23 is when you lifted off the throttle, you will get a knock count then but it wont affect the car or performace...Its a audible noise that is picked up, no biggie. I picked up 9 counts at 7000 rpms and was 0 until then but it was when i lifted and started slowing down....you will see that, other than that 1-2 counts is nothing at all. From what I heard, worry a little at 20, worry a lil more with 30, and when you hit 40+ its just plain funny to see it on your log chart but still wont hurt anything unless you prolong it....This is from my friend with a 1G who is very familiar with ecu tuning....but your 23 counts comes at the moment you lift so it doesnt even count. Your good to go
Old Jul 11, 2006, 07:27 AM
  #83
jcsbanks's Avatar
Not 23, that was timing, just mis-spaced log.
I've mapped out my lift off clunks as I didn't like the sound of them.
Old Jul 11, 2006, 07:51 AM
  #84
Ludikraut's Avatar
Yeah, I'd do some more logging before I would upload a map with more aggressive timing. Better safe than sorry.
l8r)
Old Jul 11, 2006, 08:36 AM
  #85
dudical26's Avatar
l8r)
I agree, I am just very surprised that I would be getting knock on a bone stock evo with 93 gas in it. It was warm last night but not super hot. Unless it is common for Evo's to get some knock even in stock form, I think the only likely culprit is bad gas.
Evo Girlie
84
Jul 20, 2008 09:29 AM
Evo Girlie
Sep 15, 2006 06:21 AM
Girlie
Aug 7, 2006 06:30 AM
Girlie
Jun 19, 2006 10:16 PM
Girlie
Mar 11, 2006 07:42 PM
Quick Reply: First datalogs, please comment
