Vehicle speed sensor DTC
Old Jul 8, 2006 | 10:02 PM
Girlie's Avatar
Is anyone else getting this code via Evoscan? I don't have a CEL, but it shows up under the codes when I use EvoScan to pull them. Clearing it results in it coming back on immediatley. Is it just a glitch?
Girlie
Old Jul 8, 2006 | 10:05 PM
MalibuJack's Avatar
Not sure if its a real code or not.. I see it on my car with Evoscan, but it doesnt turn up in the snapshots with my other scanner.. What is interesting is I did notice that the vehicle speed sensor does drop out periodically... never noticed it before until I got logging fast enough to capture it.. (the ECU+ logs vehicle speed and drops out occasionally)
Old Aug 5, 2006 | 08:19 PM
-=SPECTRE=-'s Avatar
I have the same issue. EVOScan frequently shows the following codes:
VSS
knock sensor
barometric pressure sensor
fuel injector circuit
I am 99% sure these are false codes. I have no MIL and the car runs fine. I think it's a bug in EVOSCAN.
Old Aug 5, 2006 | 08:37 PM
cpoevo's Avatar
I havent had any codes with Evoscan. I dont like the way it logs. I am still trying to get my injectors sized right, but the fuel trims on Evoscan are worthless. I just use my Pocketlogger.
Old Aug 6, 2006 | 12:22 AM
elhalisf's Avatar
same issue here.
Old Aug 6, 2006 | 06:35 AM
MalibuJack's Avatar
The codes in EVOScan are not real codes, not sure what it is but they don't "exist" also the clear codes function doesn't work.
Old Aug 6, 2006 | 01:04 PM
Rob W.'s Avatar
I was getting Barometric Pressure and Vehicle Speed codes too. I then kept re-checking serveral times over a minute or two (w/out clearing them) and the Barometric Pressure one dropped off the list but Veh Speed stayed. A few more clicks and Veh Speed dropped off too (no codes remaining). Checked again and Veh Speed came back. This was all while idling in my driveway, btw. I say it's a glitch in EVOscan.
Old Aug 6, 2006 | 08:46 PM
zze86's Avatar
same thing here, although I couldn't get it to clear with evoscan. Had to use my other datalogger to clear it.
Old Aug 7, 2006 | 06:24 AM
Drifto's Avatar
I've got the VSS code as well. It has turned on the light before and I could not clear it until I disconnected the bat.
Old Aug 7, 2006 | 06:30 AM
Drifto's Avatar
Perfect fuel trims stay around 100% and every 4% variance is 1% on your datalogger. So if your fuel trims are 76% at idle then they are 6%rich.
100-76=24, 24/4=6%. Higher than 100 means the computer is having to add fuel so the car is lean. Lower than 100 means the car is removing fuel so it is rich. I have verified this using a MAC scan tool.
Girlie
Jun 6, 2019 11:11 PM
hispanicpanic
Apr 9, 2016 01:16 PM
Evo Girlie
84
Jul 20, 2008 09:29 AM
Evo Girlie
Jan 1, 2006 04:14 PM
Evo Girlie
Aug 25, 2005 01:26 PM
