2 step launch control @ 6,000 rmp
Old Jul 11, 2006 | 02:36 PM
Evil_1's Avatar
I'm only seeing 5 psi of boost. Could my turbo be shot? I thought at 6,000 you should be around 10-12 psi or higher. Car still drives fine and making decent power. I've already checked for boost leak with compressed air and no signs of leak. Any ideas why I'm not building more boost with launch contorl?
C6C6CH3vo's Avatar
Check your email now, the first had the wrong fuel, check the second email
Old Jul 11, 2006 | 02:44 PM
C6C6CH3vo's Avatar
If your using stationary rev limit as two step you wont build more than 10 psi at 5000rpm with stock turbo. I wonder if we can add fuel at the respective load (40?)to help raise the boost.
If you have a way to tighten the BOV then you might get another 2-3 psi
Old Jul 11, 2006 | 03:07 PM
Evil_1's Avatar
Thanks man....I have the RS BOV, I'll try adjusting it and see if it'll build more boost. All I see if just a tad higher than 5psi. Kind of sucks for me.
Positron
Driving Techniques
Oct 16, 2008 09:27 PM
worksevo89
18
Sep 7, 2008 03:56 PM
Evil_1
Aug 14, 2008 04:39 PM
Waz996
Jul 20, 2007 08:56 PM
EVOIX4me
Aug 28, 2006 08:50 AM
