Help with injector scaling
Old Aug 9, 2006 | 09:55 PM
Kings Fan's Avatar
I downloaded my stock IX rom, but when I open up the injector scaling and this is what I see:
When I try to change the value ecuflash crashes. Here's the info on the rom:
Any ideas? I also tried several other maps (Evo8) and the value loaded fine. Thanks in advance
Old Aug 9, 2006 | 10:15 PM
Evo_Jay's Avatar
A week or two ago, I installed a vista patch and when my computer was vista style, I couldn't see the numbers in a couple boxes. I didnt try to change numbers I couldn't see, and my program didnt crash. I went back to XP style and everything was fine.
Old Aug 10, 2006 | 09:03 AM
Kings Fan's Avatar
Additionally, I'm a lil hesistant to make changes to the map and flash it back to my ecu because of this value..... please help anybody?? What's the easiest way to get a hold of Colby?
Old Aug 10, 2006 | 09:41 AM
Ludikraut's Avatar
You might want to post your ECU ROM file either here or on openecu.org. It is possible that the default definition used for the Evo IX is not correct for your ROM, which means that a new XML definiton needs to be created for it.
l8r)
Old Aug 11, 2006 | 10:49 AM
justchil's Avatar
Yeah I've seen this when I turned my font size up. You should be able to edit the field tho.
Old Feb 7, 2007 | 03:46 PM
joedr's Avatar
EvoM Moderator
I am having the same issue on my IX MR.
If there is a volunteer that may want to take a look of the hex file.... please pm me ur email and will forward it to you.
Old Feb 7, 2007 | 07:36 PM
JohnBradley's Avatar
You have the Type 13 rom. Injectors scaling is not available. All you have to do is flash it with a Type 15 and build off of that map. Not really a big deal, but nothing that I have tried has been able to bring the function back in the 13 and 14 roms. Its a glitch in some code somewhere but frankly beyond me.
Old Feb 7, 2007 | 09:01 PM
joedr's Avatar
EvoM Moderator
JohnBradley,
Thanks for the info!
If I am building off a Type 15, should I leave it at 513 cc/min as the injector scaling? That is what I can see in the stock Type 15!
Old Feb 7, 2007 | 09:17 PM
That is correct, no need to change that until you go to larger injectors. When you flash this for the first time it takes about 2 minutes to completely reflash the car versus the usual 15-20 seconds if you reflash with the same rom type.
Old Feb 7, 2007 | 10:59 PM
joedr's Avatar
EvoM Moderator
Thumbs up
Thanks for the insight!
I am porting all of my tables into a rev 15. Will do some logs on my WB to fine tune it after the porting if needed!
Old Feb 10, 2007 | 11:15 AM
Cyloc's Avatar
mine comes up at 513cc
evotuner04
Dec 6, 2015 12:07 AM
rEvolutiondan
Sep 14, 2013 03:43 PM
InSw1TcHeDFlame
Nov 26, 2010 02:31 PM
InSw1TcHeDFlame
Nov 25, 2010 07:55 PM
AznDragonV
Jun 24, 2008 02:28 PM
