Need help with Evoscan
Old Aug 15, 2006 | 09:34 AM
nj1266's Avatar
Guys,
I just got my tactrix cable. I also have Evoscan and Ecuflash installed on my laptop. I plug the cable in the laptop USB port and the laptop sees the cable.
But when I open Evoscan and tell it to log I get this error message:
Unable to load DLL (FTD2XX.DLL).
How do I fix this? I already have Ecuflash installed so the FTD file should be in there.
Please help
Old Aug 15, 2006 | 09:58 AM
-=SPECTRE=-'s Avatar
try moving the cable to a different usb port maybe
Old Aug 15, 2006 | 10:42 AM
lvNVevo's Avatar
I had the same error but as soon as the cble was pluged in it went away. make sure your selecting the cable as the port you want to use in ecuflash. go to options and the cable should be there, if not uninstall and reinstall with the cable pluged in. Once ecuflash sees the cable ecuscan will be good to go as well..
nj1266's Avatar
Thanks, but I fixed it. For some reason the Windows driver wizard was not poping up. I pulled the Tactrix usb plug and pullged it in the USB port and the Wizard popped up. Then I told the Wizard where the dll file was. It worked.
Inprogress
Dec 22, 2015 04:25 AM
CDrinkH2O
13
Apr 28, 2014 08:08 AM
craig05evo
Aug 2, 2013 08:26 PM
bigben
Feb 26, 2012 06:42 PM
Nissan2Evo
Apr 26, 2009 08:59 AM
