New injectors
Old Aug 20, 2006 | 12:04 AM
cpoevo's Avatar
New injectors
Well I switched from the Greddy720's to PTE 780's. After about20 flashes the car still ran like **** with the Greddy's. I installed the Precision 780's and did 2 flashes to scale the injectors and the car runs good. I will have to do some more logging tommorrow, but the car drives better now.
Old Aug 21, 2006 | 07:51 AM
Stew's Avatar
Did you tune your fuel maps after scaling the injectors?
Old Aug 21, 2006 | 09:58 AM
RazorLab's Avatar
Interesting that you couldn't get the denso 720's to work well. Mine purr like a kitten.
What specifically was happening when your car "ran like ****"?
Old Aug 25, 2006 | 12:14 PM
cpoevo's Avatar
The fuel trims were all over the place. I tried about 20 different flashes to get them sized and the trims were way off. I got the trims good at idle, but the trims at cruise were way off. I just got frustrated and said screw it. Even with the AFC I was unable to get the car to run smoothly. The trims would be almost perfect at cruise, but when I would let off the throttle the car would die or stumble real bad. The car wouldnt even run when the AC was on. I switched to the 780's and everything is fine now. I was able to smooth the cams out a little better and the car Idles fine and the cruise trims are pretty close. It even runs fine with the AC on. I still need to fine tune the latency a little, but the trims are real close.
AWD_Terror
Apr 1, 2009 09:27 PM
Muad
Feb 18, 2007 02:29 PM
kiddevo
Sep 4, 2006 07:30 PM
dsevo
Feb 14, 2006 04:47 PM
TomsEVO
Automotosports - Illinois
Dec 26, 2005 08:46 AM
