what is this?
Old Aug 24, 2006 | 08:12 PM
nothere's Avatar
what is this?
http://www.gems.co.uk/ems/rallying_features.html
waiting to hear back, it sort of sounds like ecuflash with a built in logger. has anyone any further information?
I know Gems is related to AEMS but ths looks to be something a little different.
Old Aug 24, 2006 | 08:16 PM
nothere's Avatar
The hardware - injectors, coils, sensors and so on - specified by the manufacturers of most road cars is usually readily adaptable for motorsport purposes. The problem is the software provided with the standard original equipment (OE) electronic control unit. Often, this is inflexible and inappropriate, making the system difficult to reprogram when changes are needed after modifications to the engine.
GEMS software implants use all the original hardware, including the original OE 'black box' itself, but replace or add a GEMS ECU board with specialist motorsports software based around the techniques used in GEMS racing engine management systems. This product is especially useful and appropriate to those involved in Group N racing or rallying, where retention of the original ECU case and sensors is mandatory. The GEMS Mitsubishi Lancer and Subaru Impreza implants have been highly successful in this arena.
The GEMS software implants transform the host ECU from an inflexible black box into a user-friendly engine management system which requires a minimum of electrical knowledge to operate. This includes the addition of a communications link that allows the operator to monitor and control the system.
Fuel control is by three-dimensional lookup tables using throttle position and engine speed for normally aspirated engines, and manifold absolute pressure and engine speed for turbocharged engines. If the original system uses an airflow meter this can be retained if necessary. Ambient air temperature, coolant temperature, barometric pressure and battery voltage are measured and used to compensate for prevailing conditions - altitude, temperature, etc.
Ignition is controlled by the same inputs as fuel using another three-dimensional lookup table, and a wide array of programmable functions are available.
The GEMS software allows the standard GEMS monitoring interface to be used and allows control and reprogramming via the Serial Link as for other GEMS ECUs.
Basic calibrations are available for all implants but need fine tuning for different fuels, restrictor sizes and engine modifications where applicable. GEMS can recommend a number of suitable tuners to do this work if necessary.
Old Aug 25, 2006 | 06:29 AM
MalibuJack's Avatar
FWIW it looks to be a plug and play EMS system designed to fit into the stock ECU Case.. (See the Autronic P&P board)
It also appears to be the origination of the AEM EMS Plug and Play ECU...
Old Aug 25, 2006 | 06:33 AM
nothere's Avatar
you might be right, I may have misread this para.
Old Aug 25, 2006 | 06:01 PM
andenbre's Avatar
one thing to watch out for is the gems is probebly aimed at only euro and jdm cars that have different sensors and equiptment compaired to usdm cars. for eg the 3 bar boost sensor and temp sensor in the manifold used by the edm evo ix for a direct value for the ecm to use where the us uses a caculated boost value and calculated manifold air temp based off of maf hz rpm, tps, 1 bar map, baromtric press sensor, maf air temp
Astro_Train
Dec 24, 2016 07:13 PM
Jonno99
Mar 9, 2016 07:51 PM
EvoCop
Northwest Region
46
Jun 8, 2010 02:07 PM
feautoevo
For Sale - Cars For Sale
10
Jun 23, 2007 06:40 AM
evoCS
21
Sep 22, 2006 08:19 PM
