35r and EvoFlash. Lets see what happens...
Old Oct 15, 2006 | 08:12 AM
  #91
Dominos's Avatar
Originally Posted by MalibuJack
Check your trims.. Looks like its way out of range either at idle or cruise..
I found the AEM wizard made a good starting point, but I ended up using LESS latency and a smaller injector size and ended up having better results when the trims are in check..
Beat me too it...
Hey I notice you are running BPR9's
Have you tried none protruding plugs?
Old Oct 15, 2006 | 03:14 PM
  #92
MalibuJack's Avatar
Nope, haven't tried the BR9's yet.. HOWEVER, I do have a few sets of different types of plugs that I will try as I do more tuning. I'm waiting on some replacement electronics for my blowthrough meter before I finish tuning my car.
Old Oct 15, 2006 | 04:48 PM
  #93
A418t81's Avatar
I guess all stock ignitions aren't created equal? I had a problem with my boost control and was getting up to 24 psi on pump fuel with the stock plugs gapped to .028 or even higher. The car never missed a beat.
Old Oct 15, 2006 | 04:55 PM
  #94
MalibuJack's Avatar
The age and wear on the plugs, condition of the coils and wires, all have an impact.. I can run a looser gap, but they wear pretty quickly and you get misfire within about 3000 miles..
Old Oct 15, 2006 | 04:58 PM
  #95
AlwaysinBoost's Avatar
damn stock plugs @ .028 huh, I'm using br7es gapped @ .024, maybe I'll try opening them up a bit next time i switch.
I know I was getting misfires @ .028 with the stock turbo & 24psi...
Old Oct 15, 2006 | 05:04 PM
  #96
A418t81's Avatar
They aren't new plugs either, I've got at least 25k on them
Makes me wonder if the p0300 and ignition system "strength" go hand in hand. I have a younger brother with an 03 Evo also and he has had problems with the 0300 and random misfires at WOT with mild mods and a narrow gap. I on the other hand have never had a 300 other than when I was adding timing with the Xede and my car has never misfired under WOT.
Old Oct 15, 2006 | 05:06 PM
  #97
Dominos's Avatar
The Br's (no P) allow a bit more advance in the midrange. At .024 they work really well up to about 28 on th stock turbo.
Had mine to about 33 psi on the 35r and they are still ticking well.
Old Oct 15, 2006 | 05:09 PM
  #98
A418t81's Avatar
What heat range did you go with?
Old Oct 15, 2006 | 05:11 PM
  #99
Dominos's Avatar
Br9's and the Br8's. The 8's work better
Old Oct 15, 2006 | 05:13 PM
  #100
br7es are 1/2 heat range colder then the brp7es.
as far as midrange timing goes... what kind of numbers is everyone running? I'm targeting about 7-8* @ 5500 RPM and it ramps up to 15-16 by 7k.
Old Oct 15, 2006 | 05:14 PM
  #101
plugs are cheap so I replace them often. I have a set of br8es gapped at .024 waiting to try...
Old Oct 15, 2006 | 05:42 PM
  #102
A418t81's Avatar
I'm thinking about swapping mine out to see if there's anything to gain.
Old Oct 15, 2006 | 08:09 PM
  #103
Dominos's Avatar
you won't be sorry with the 8's
Old Dec 17, 2006 | 04:48 AM
  #104
Spooldyou's Avatar
def bringing this back from the dead. But,
Going with a DSM 1g ignition setup and a 3m Blow through.. What you guys think?
Old Dec 17, 2006 | 07:30 AM
  #105
MalibuJack's Avatar
I'm assuming you mean GM Blowthrough??
One of the best upgrades is the 1G Ignition setup, or a 1G Igniter and 300m coils..
