problems everywhere lol
Old Sep 4, 2006 | 06:57 PM
honki24's Avatar
sorry guys. I just suck at computers. I was trying Jack's load thingy for evoscan. Not much luck w/ that either. It "digested" a log and output a small portion of the log with the load added (yay!), but it was only up to 85 samples... significantly less than were in the log. Also, it did output the file... but not cleanly. I got an error (which coincidentally I sometimes also get with evoscan) for which I have attached the screenshot and details thereof. If anyone can help, remember that I suck at all this xml whatever stuff lol.
click here to help me lol
Old Sep 4, 2006 | 07:01 PM
mchuang's Avatar
You are dropping the excel file in the wrong spot. You need to drop it exactly where it has the letters and not in the white empty area. I got that error the first time I tried it also because I dropped it in wrong spot
Old Sep 4, 2006 | 07:06 PM
honki24's Avatar
lol, yeah I did that initially, but no I got it in the right spot and I'm still getting that error. Like I said, it does make the file... but it's truncated and I get that error at the same time... just not exactly as I'da thought it would have happened. I thought there would be some sort of confirmation, but perhaps it's not there b/c of the error screen.
Old Sep 4, 2006 | 07:34 PM
MalibuJack's Avatar
There's two possibilities.. A problem with the source file, or you exited the program before it was complete.. The file is not complete until you see the bottom box show the new filename.... If it doesnt and you exit the program, you'll get a partial file. And the program is drag and drop, there was a reason for that, basically you can take several files and drag and drop them to convert them, and the file is written to the same location where the source came from..
Again, if you exit the program before its done (it should finish before it lets you exit, but since I forgot to disable the quit button, and I never added a dialog for when the files are completed) I wrote this tool for myself, so I never took error handling or user error into account.. I can set it up to disable the exit button and show a status of some sort (or a completion message) if you guys want.. Like I said, I wrote this tool for myself so I did very little to make it very intuitive, just easy for my "workflow".. Thats why it hovers on top of everything and is drag and drop..
Old Sep 5, 2006 | 06:20 AM
honki24's Avatar
I understand, but now I see that the error message is probably what cut the program short and caused a truncated file. So what do I do about the error message? That seems to be the problem. Again HERE's the link to the zip file containing a screenshot and a .txt of the error details.
thanks all.
Old Sep 5, 2006 | 06:22 AM
troe666's Avatar
looks to me like a value was blank and it wanted a decimal format number in there.
anywhere youve left blank that you could enter 0 (zero) or a value for?
just based on the error. its a runtime error generated because the code did not handle the exception. I know it has expected a decimal and gotten a blank value because of the type conversion failure.
Any IT questions feel free to throw my way am pretty experienced engineer
but ive barely touched EcuFlash until now so give me time to learn hehe if you have no values left blank or everythings as expected let the writers of ecuflash know and theyll have to sort it out with a patch or in the next version man
Trav
Old Sep 5, 2006 | 06:40 AM
jcsbanks's Avatar
Trav, I hereby accuse you of being an IT engineer and demand your help with disassembling this blasted Evo ROM You do not have to say anything blah blah blah but it is driving me nuts and I could use some help.
You have a PM!
Old Sep 5, 2006 | 09:23 AM
honki24's Avatar
hmmm, there are blank values, I'll try to fix that. Thanks man! I'll letcha know.
Old Sep 5, 2006 | 11:21 PM
troe666's Avatar
You have a PM!
You too! I'm definately quite experienced in C and years in security and some protocol work, I'm not familiar with some of the evo ROM concepts yet so let me bring myself up to speed over a week or 2 and ill definately do anything i can to help My tactrix cable or what-not is on its way, along with reflash jumper block etc
seems like the most likely reason, usually in code there is integrity checking before the application tries to store the entered values. Quite often it will convert from string to a decimal or binary or whatever on an input field. If that field is blank, and the code doesnt not perform validation on the input fields, when it tries to store the value into memory or table field etc it will cause a type conversion failure as it got data (blank string or totally null) when it expected something. I cant say for definate whether ECUFlash is just expected you to enter a value and you havent (or it requires 0) but its worth a try - thats something YOU can do
If youve entered everything as expected, then ECUFlash could be doing something buggy internally and hence the same runtime type conversion error will occur. In which case there's nothing you can personally do other than submit the error to the ECUFlash authors and see if they can assist, along with the bin or hex you are trying to apply/save if this is possible.
Sorry I couldnt be more specific help,
Trav
Old Sep 6, 2006 | 04:46 AM
honki24's Avatar
you were right, apparently I have to log all values so that there are no blank columns and vioala, the program works flawlessly. Thank you all much.
Old Sep 6, 2006 | 08:38 PM
TTP Engineering's Avatar
I get the decimal error also. Hopefully this can be cleared up in the software.
Honestly, I never had a problem determining load based on ignition timing tracing, but this will be a good tool for the newbies to help them get a feel for what is going on if it remains accurate.
Old Sep 7, 2006 | 08:42 AM
MalibuJack's Avatar
I posted this in the Log Analyzer thread on my forum.. But understand I wrote the program for my own use, and made several assumptions because of that.. I didn't make any extra effort to handle errors that I knew didn't happen in my workflow.
Although the program runs fine as long as you select the right columns, it might have a problem if you ONLY select 3 or 4 columns and the last column shown is either AFRMap or InjPulsewidth.. This was a coding error (shortcut) taken on my part to speed up the digestion process.. My workflow does turn on ALL of the log data since I do get a very high sample rate with my laptop.. But I have turned several off out of curiosity and had no trouble with it.
What I did see happen FREQUENTLY was if someone opened the CSV file in Excel, do something with the data, then re-save it.. it WILL NOT WORK, partly because Excel reformats the date and time columns slightly which is different than the original Evoscan log format. If you want to work with the data in Excel, and need to cut/trim/save, you should do it after converting it. (Again, that was not part of my workflow so I never initially noticed that Excel reformatted it)
You don't have to have all the columns enabled, and it won't croak on blank data, however it will choke if some of the columns that are needed are missing..
The load calculation is most useful in determining load if you have several adjacent cells with similar values, are experiencing knock, or your octane number isn't 255 (for whatever reason..) Conditions like that would make "hand tracing" quite a bit more difficult and time consuming. But I do actually do that on occasion if its necessary.
I have gotten some word that the functions that the analyzer does, will be part of the next release of Evoscan, I think he also mentioned he fixed the logging so the sample format (time stamp format) is easier to bring into data log lab, so you won't need this tool any longer at that point..
Old Sep 7, 2006 | 08:45 AM
MalibuJack's Avatar
FWIW the only time I ever saw any "Decimal" errors was when the data was opened in excel then resaved as a CSV..
For it to crap out after 85 or so samples is just strange since my logs are typically 5mb in size, are you including the header line (first line of the log) ? That line is required for the program to determine the right format.. I also realized I made an assumption about what column the time stamp data is in.. and I saw some of you guys had different output at times for those columns..
Don't forget I also have a Data.XML file that I included with the program.. It was only tested with that file. If your using your own I can't be sure of anything its doing since you could have duplicated column names, different order, etc..
dEVOted_ix16
May 14, 2014 02:35 AM
ehall20
Apr 3, 2014 03:38 PM
richardjh
May 24, 2013 01:53 PM
555R
15
Jan 23, 2010 07:36 PM
