Evoscan 0.9 map reading
I just did some data logging and the map is read in kpa? Accordind to my logs I was hitting 329kpa whis is something like 40 psi how do we get an accurate psi conversion from evoscan.
subtract 14.7psi from your measurements.
1) The conversion factor in the Data.xml file is wrong for the US model Evo.
2) The pressure sensor on the US model Evo is only used for vacuum. The output that Evoscan reads from the ECU peaks at 0.22 bar (about 3.3 psi).
If you want to see the value in psi relative to atmospheric pressure, replace "1.334x" with "0.072x-14.7".
The definition suits the JDM Evo IX with its 3+ bar MAP sensor. Having found the requestID whilst looking for load and stumbling across the MAP sensor, I calculated the 1.334x definition from the Evo IX service manual and supplied it to Hamish. Perhaps we might end up with a few different MAPs/MDPs in the definition and the one most appropriate will be selected, or the definitions will branch for different models.
i input the new formula and I peaked at 3.03 is there another conversion to get the psi.
Originally Posted by MalibuJack
Its the max of the sensor.. I am going to swap my USDM sensor for a JDM 3 bar sensor and see if it fouls things up..
Originally Posted by mchuang
Good info thx havent used it yet. I really want to see how lm1 works with evoscan with the rpm converter.
Originally Posted by nj1266
What are you using to connect the LM-1 to Evoscan?
I meant to say without the rpm converter my bad. I will use the serial connection just waiting for my o2 sensor cable to come in since my other one was cut while moving some how.
