Evoscan 0.9 map reading
Old Sep 11, 2006 | 11:54 PM
mchuang's Avatar
Originally Posted by nj1266
Do you have to disconnect the rpm convertor from the LM-1 so it can log with Evoscan? Can't we just use the serial output cable from the side of the LM-1 box (the port we use to download to the pc) and connect that to Evoscan and log?
Yea that is the way it is suppose to be done and that is how the zeintronix is working.
Old Sep 12, 2006 | 05:06 AM
AlwaysinBoost's Avatar
I tried that on my car and it doesn't work with v.9
Old Sep 12, 2006 | 10:18 AM
mchuang's Avatar
Man then I have no clue..did you try diff com ports or is there a specific baudrate recommended that you must change to??
Old Sep 12, 2006 | 02:53 PM
C6C6CH3vo's Avatar
I didn't even know the manifold had a pressure sensor besides the differential pressure sensor - that reads the change of psi accross the TB flapper
Old Sep 12, 2006 | 03:03 PM
jcsbanks's Avatar
Think it is just JDM IX that reads boost.
Old Sep 12, 2006 | 04:07 PM
andenbre's Avatar
Originally Posted by MalibuJack
A friend in Taiwan is going to hit the parts department this weekend for me.. If it works, I'll arrange to get a few of them.
If it works without buggering up the usdm I will be very willing to take one off your hands(obviously with reimbursment)
pm me here or on active matrix
Old Sep 12, 2006 | 04:19 PM
mrfred's Avatar
I thought that the MDP sensor was at the opposite end of the intake plenum from the throttle butterfly.
Old Sep 13, 2006 | 11:51 AM
taenaive's Avatar
Group Buy!
Old Sep 13, 2006 | 04:21 PM
C6C6CH3vo's Avatar
If it's cheep enough. I wouldn't mind a wigget boost guage
Old Sep 14, 2006 | 06:29 PM
RedV's Avatar
Not that I'm qualified to be saying this, but what the hey, I will anyways...
I would think that if you just throw the JDM IX MAP sensor in there that it's gonna throw some kind of code and you'll get an SES light. Won't the ECU see an unexpected reading/voltage from the MAP sensor and freak out? I kinda home I'm wrong though. Maybe it'll just keep humming right along and just report the higher value, who knows.
Old Sep 14, 2006 | 07:27 PM
MalibuJack's Avatar
Don't know, thats why I'm trying it
Old Sep 14, 2006 | 08:44 PM
mchuang's Avatar
Yea more than likely since there is currently no way to calbirate the voltage.
06Black
Jul 6, 2016 12:43 PM
poncho8667
Aug 26, 2013 09:36 PM
nonschlont
Aug 26, 2011 12:08 PM
darkmitsu
Lancer Engine Management / Tuning Forums
May 19, 2010 08:37 PM
cec12789
Aug 8, 2009 01:35 AM
