Evoscan 0.90 problem
Old Sep 11, 2006 | 12:47 PM
Fredd^'s Avatar
Hi
I get error message when starting the datalogger
Info: Initialising At 5 baud 0x00...
Info: Initialisation Complete...
Info: Waiting for INIT Response...
Info: Connection successful...
Error: Canīt convert string Err to type Double.
Has anyone had this problem ?
Thx
Fredrik
Old Sep 11, 2006 | 12:50 PM
jcsbanks's Avatar
, instead of . as decimal point
Old Sep 11, 2006 | 01:00 PM
Fredd^'s Avatar
Sorry but I dont understand ?
Old Sep 11, 2006 | 01:22 PM
donour's Avatar
There was an error in the config file. The application was throwing an exception and the data conversion code isn't smart enough to catch it.
d
Old Sep 11, 2006 | 01:26 PM
mrfred's Avatar
One of your formulas has bad syntax. Did you modify any of the formulas?
Old Sep 11, 2006 | 01:27 PM
Fredd^'s Avatar
d
Okay
How do i solve it ? I have tried to reinstall the program but still the same problem.
Thx
Fredrik
Old Sep 11, 2006 | 01:28 PM
Fredd^'s Avatar
No just got the program and installed it, i havent modified anything.
Maybe i need to manually uninstall the program, will try that right away.
/Fredrik
Old Sep 11, 2006 | 01:43 PM
A418t81's Avatar
No, the problem is that you guys use a comma (,) instead of a period (.) to delineate numbers
For example, you use 6,25 when evoscan is setup to see 6.25
Old Sep 11, 2006 | 01:51 PM
Fredd^'s Avatar
Okay i dont know what you mean but i have only installed the program and pressed Start datalogger, I havent change anything, cant see any comma either.
/Fredrik
Old Sep 12, 2006 | 06:01 AM
Fredd^'s Avatar
Does anyone have a clue how to solve this? I cant use evoscan.
/Fredrik
Old Sep 12, 2006 | 06:57 AM
mrfred's Avatar
In "Regional and Language Options" in the Control Panel, how are numbers set to be displayed?
Old Sep 12, 2006 | 11:08 AM
Fredd^'s Avatar
Hi
I use standard Swedish keybord layout, it seems to be the same as english.
only the time that differs, we use 20:00 instead of 08.00 can that be the problem?
/Fredrik
Old Sep 12, 2006 | 11:14 AM
MalibuJack's Avatar
Hi
/Fredrik
What about fractional representation of numbers.. for instance 5.25
In some european countries its represented as 5,25
Commas are used as delimiters, so if your localization uses the comma for fractional values (decimal values) it will foul up the output and throw an error.
I know the time stamp on 0.9 changed, it does use hh:mm:ss.xxxx as the format or something similar, where previously the minute and second values were seperate columns.
Old Sep 12, 2006 | 11:16 AM
Fredd^'s Avatar
Okay, then ill try to install english windows with english keyboard layout and all other reigional settings ?
Old Sep 12, 2006 | 11:24 AM
MalibuJack's Avatar
Thats probably a good idea if you can start over easily. Otherwise you just need to set your numeric settings to use the USA format for time and decimal representation.
