Injector pulse width
Old Mar 9, 2007 | 06:30 AM
  #46
mrfred's Avatar
Originally Posted by cij911
Mrfred -- I have a Zeitronix wideband and use it to record my boost, AFRs, etc.
Anyone else ---- ??? Thanks
If its not going lean on the Zeit, then you've answered your own question about the injectors. I think that for the boost level your hitting with your current bolt-ons, you need a bit less ign advance.
Now if you're thinking about adding alky, then you'll be up for a complete retune to maximize power. You'll end up leaning out the afr slightly and possibly increasing ign advance further than where you're at now
Old Mar 9, 2007 | 08:06 AM
  #47
nj1266's Avatar
Here is what I would do if I had your problem:
1. Check for leaks in the exhaust system just to make sure that my AFR readings are correct.
2. Re-calibrate my Bosch O2 sensor. These things tend to give different readings based on age and environmental conditions.
3. Reduce boost to 22-23 psi and see if IDCs go down
4. After reducing boost, pull timing by about 2* in the upper rpm range, from 6K to cutoff.
5. After reducing boost and pulling timing, lean out the AFR some more and your IDC will go down.
Old Mar 9, 2007 | 08:10 AM
  #48
cij911's Avatar
Thanks Naj....There are no exhaust leaks and the O2 sensor is spot on....I may just reduce boost a tad...
Old Mar 9, 2007 | 11:51 AM
  #49
cpoevo's Avatar
With the mods listed in my sig I am running my 780's at 80% at the highest IDC on 91oct and AFR 10.8
Old Mar 9, 2007 | 11:56 AM
  #50
Mellon Racing's Avatar
that sound awfully high for the mods you have listed... it must be because of the rich AFR
Old Mar 9, 2007 | 12:26 PM
  #51
jaap's Avatar
Can you go to larger injectors without new tuning ??? Just a bit larger to be safe ? If so what size ???
Old Mar 9, 2007 | 12:28 PM
  #52
jaap's Avatar
Injector size
Old Mar 9, 2007 | 12:42 PM
  #53
the stock injectors are actually pretty good sized, they don't really become a problem until you do a turbo upgrade.
Old Mar 9, 2007 | 04:18 PM
  #54
nj1266's Avatar
IMO, you should set the boost @ 22.5 psi. This way it will fluctuate between 22 and 23 with weather changes. That is the way I have mine set. Pull timing a couple of degrees and lean by about 0.2-0.3 AFR. I run conservative timing (no more than 16*) and a solid 11.5-11 AFR. The IDC hits a maximum of 92% @ 7K rpm. The car still put down 312 hp and 299 tq using DLL. Some times less is more
Old Mar 10, 2007 | 04:06 AM
  #55
cij911's Avatar
I understand your perspective and think that I may land close to there....I will be dyno tuning the car later today and see what is best. My guess is that I will land somewhere around 24 psi peak tapering to 18/19 psi @ 7K. Thanks again!
Old Apr 9, 2007 | 01:58 PM
  #56
Spooldyou's Avatar
Originally Posted by MalibuJack
It takes time, but the trick is to start really rich, smaller size and leave the latency what is documented for the injectors (use the AEM calculator)
Then, you adjust the scale until your fuel trims at idle are very close to zero..
Then drive the car around for awhile, and see how off the long term fuel trims get after a long drive.. At that point you can adjust the 11v and 14v injector voltage latency settings until overall you get your trims while driving in check.. Then you'll have to adjust idle one more time.
What this will do is it should get your fuel injectors, to read "ROUGHLY" close to what your fuel map looks like by the numbers.. Its not quite right, but it should be similar..
Doing this will give you the best drivability and then you can tune your maps... Just remember to make the maps rich to start before you do too much..
Does this mean start on the stock Fuel map?
Old Apr 10, 2007 | 07:22 PM
  #57
tkklemann's Avatar
Let me add that my car has a stable voltage of 13.7v that doesnt drop more than 3/10ths of a volt at idle, and never has gone over 13.9v ever.. So my latency values are acting more as a scaling modifier.. I need some sort of dead time value that will be affected by RPM, at idle dead time isn't as critical as at higher RPM, so when I get perfect trims at idle, it runs lean at higher RPM, and if I get it where I want at high RPM, the idle is too rich for the trims to compensate..
This is partially the MAF curve I'm working with, but the values themselves are within range and reasonable values for the level of boost I'm currently running.. so its obviously related to dead time (or some compensation)
In reality this isn't an important issue for me.. However I spent some time trying to match the injector scaling so my AFR's are similar to what the arbitrary AFR values in the map show, for me it would make quick adjustments easier. Plus I'd rather have to take fuel away than add fuel to the maps..
Just a thought, maybe it's late and I need to go to bed...
Can you/is it possible to rescale the voltage on the latency tables for more resolution between the 11v and 14v?
Say, get rid of the 7v because I can't see at least my car ever even comming close to having that low of voltage, and put a voltage of 12 inbetween the 11 and 13v for beter resolution?
Old Apr 11, 2007 | 07:25 AM
  #58
MalibuJack's Avatar
Well, as far as I know all of the values are needed. I honestly don't know what will happen if you change the axis values like your describing.
Old Apr 11, 2007 | 08:12 PM
  #59
tkklemann's Avatar
Chop Chop then........
P.S. Just Kiddin!
lexa609
Sep 25, 2016 02:34 PM
ridenrunwv
Sep 29, 2015 09:59 AM
aronjaskim
26
Aug 20, 2010 07:08 AM
PlanoEvo
Dec 5, 2009 06:05 PM
recompile
29
Jun 21, 2007 07:07 AM
