Anyone having this problem with v0.9?
Old Sep 13, 2006 | 01:10 PM
nj1266's Avatar
I used to open the Data.xml file of the ver 0.8 and edit the order in which the parameters appeared in the log. I liked to see RPM, timing, KS and octane next to each other and it worked fine in ver 0.8.
When I tried to do the same thing in ver 0.9 I get an error mesage "cannot open com port 1." Whne I use the Data.xml file as is, then the program works fine.
Did anyone experience the same thing? How did you fix it?
Old Sep 13, 2006 | 02:04 PM
mchuang's Avatar
Nah I was able to edit mine in notepad just as always
Old Sep 13, 2006 | 02:20 PM
mrfred's Avatar
I moved several definitions around without causing issues in EvoScan v0.9.
Old Sep 13, 2006 | 03:19 PM
nj1266's Avatar
Then I must be doing something wrong. I tried it twice and both times Evoscan gave me an error message.
Can you guys share your xml file? I want to try it and see if your works in my program.
Old Sep 13, 2006 | 03:37 PM
chrisw's Avatar
to verify that your edits of the XML file are valid, try loading it into IE. If IE can't parse it, then you have a syntax error in the file somewhere.
Old Sep 13, 2006 | 07:29 PM
Kyle_Y's Avatar
Red face
did you put a tick in wideband logging ?? or change the wideband logging to Y ??
you will see that if you enable wideband logging and did not hook up any wideband to the comport ..
Old Sep 13, 2006 | 07:49 PM
nj1266's Avatar
Yes I did...Now I know what is wrong...I have tried three edits with the same results...Now I have to do a fourth, but I will leave wideband unchecked.
Old Sep 13, 2006 | 09:30 PM
Evo_Jay's Avatar
Is there anyway to make it so everytime I open EVOscan I dont have to check the little WB square and selet my WB and port.
Also, if someone can tell me how I can make it so certain data collums can be next to each other in Excel, that would be great.
Old Sep 13, 2006 | 10:01 PM
mrfred's Avatar
Go into the "Data.xml" file (using TextEdit or Notepad) and change the "Y" to "N". You can also rearrange the ordering of the definitions.
Old Sep 14, 2006 | 03:41 AM
Evo_Jay's Avatar
Does anyone know how to make it so I dont have to select what WB I have and the com port??
Old Sep 19, 2006 | 08:50 PM
Evo_Jay's Avatar
^^bump
bobby.is.rad
Apr 29, 2015 07:20 AM
__pg
Apr 26, 2015 01:10 PM
mrfred
Jun 16, 2009 03:02 PM
Import Junky
Jan 2, 2009 09:28 PM
Thoe99
Oct 11, 2007 12:41 AM
