No direct reading of load from ECU?
Old Sep 20, 2006 | 06:39 PM
mrfred's Avatar
Since everyone is calculating load indirectly, does that mean that the request ID for load has not yet been found, or the ECU does not provide load via any of the diagnostic protocols?
Old Sep 20, 2006 | 08:54 PM
Ralph's Avatar
Good question. +1 for answer
Old Sep 20, 2006 | 09:44 PM
andenbre's Avatar
a load value has been found in the ecu however at this time we dont have a way of reading/logging it at this time. It is being worked on though
Old Sep 21, 2006 | 04:48 AM
MalibuJack's Avatar
The ECU does calculate load.. Obviously.. However a standard requestID to specifically dump that value does not appear to exist.
The good news is there has been a pretty big effort to disassemble the rom, which means that at some point we will be able to do things with the ECU..
Plans for mods include:
Outputting a MAF Frequency that isn't clipped at 1609hz
Outputting the internal ECU's calculated load value
Additional resolution to the fuel and timing maps
Altering the OCTane value with an external device manually to allow dual map functionality (This obviously would remove a safety feature)
Some level of real time tuning when the RAM locations for the maps are decoded
Additionally there are 20 or so additional configuration items and tables that affect the engine management, some of which I have some clue what they are, others I have no idea..
Closed Loop AFR Target
Injector configuration parameters (Dead time, Latency, etc in addition to the Voltage latency adjustment)
One of the AktiveMatrix members in intent on creating some sort of speed density or alternative MAF sensor swap programming.
The 02-05 ECU has 256kb of rom data, functionally I think only a small part of it is used, and of course maps, tables, and configuration parameters are all spread around in there. At some point its feasable that enough will be known about the roms to be able to pick and choose the features you want and modify it in any way you like.
Old Sep 21, 2006 | 12:12 PM
tabio42's Avatar
Load Value; Unclamped MAF frequency or Speed Density Conversion FTW!
That would be the ultimate stock ECU.
Old Sep 21, 2006 | 12:48 PM
Noogles's Avatar
or it would be like a Gen III and Gen IV GM ECU
Old Sep 21, 2006 | 01:29 PM
MalibuJack's Avatar
MAF Frequency isn't clamped in the ECU itself.. Only in the RequestID output.. Presumably its due to the resolution of using 1 byte to represent frequencies.. the higher the MAF frequency output, the lower the resolution of the output is..
This was something obviously a throwback to the days with stock turbo cars rarely reading 1609hz at max.. Once your modified you frequently go over that, but back in the day of 16-18psi max, I think the highest you'd see would be around that.
I'm running a different kind of MAF sensor, its not a karmann sensor.. The honest truth is the karmann sensor is the most accurate MAF sensor available, its that they don't make one sized for the kind of airflow our cars are capable of with aftermarket turbos (and even really nicely tuned stock turbo variants)
Old Sep 24, 2006 | 01:58 PM
FlashBlueRS's Avatar
RequestID "1C" and eval "5x/8" should give you guys load. It works for the 3G eclipse.
I pulled that from the new ecuEdit release for Mitsu's.
Old Sep 24, 2006 | 02:21 PM
MalibuJack's Avatar
I hope your right... It certainly would make life easier..
Old Sep 24, 2006 | 02:29 PM
AlwaysinBoost's Avatar
I hope I'm wrong but its probably the same 'load' that my pocketlogger reads, 0-100%.
Old Sep 24, 2006 | 02:45 PM
MalibuJack's Avatar
Yeah I am guessing the same thing..
Old Sep 24, 2006 | 06:23 PM
chrisw's Avatar
so I tried a logging session with this value. I used the formula from ECUEdit's file. I added these data items to my data.xml file using evoscan v0.8
Code:
  <DataListItem DataLog="Y" Display="ECU Load raw" LogReference="ecuLoadraw" RequestID="1c" Eval="x" Unit="steps" />
  <DataListItem DataLog="Y" Display="ECU Load" LogReference="ecuLoad" RequestID="1c" Eval="0.625x" Unit="%" />
Code:
ecuLoadraw	ecuLoad	Load
39	24.375	24.37516.993125
42	26.25	26.2516.993125
44	27.5	27.522.123125
46	28.75	28.7522.123125
139	82.5	82.522.123125
91	56.875	56.87563.163125
89	55.625	55.62547.773125
134	83.75	83.7558.033125
137	85	8578.553125
131	80.625	80.62578.553125
116	72.5	72.568.293125
55	33.75	33.7542.643125
33	20	2022.123125
27	16.875	16.87516.993125
29	18.75	18.75-8.458625954198473282442748092
38	23.75	23.75-8.394545454545454545454545455
41	25.625	25.62516.993125
38	24.375	24.37516.993125
40	25	2516.993125
43	26.875	26.87522.123125
45	28.125	28.12522.123125
46	28.125	28.12522.123125
47	28.75	28.7522.123125
144	96.875	96.87522.123125
57	33.125	33.125104.203125
78	46.875	46.87588.813125
139	88.125	88.12583.683125
144	89.375	89.37583.683125
141	88.125	88.12578.553125
141	87.5	87.578.553125
132	82.5	82.578.553125
144	90	9073.423125
159	99.375	99.37588.813125
172	107.5	107.593.943125
180	113.125	113.125100.05176470588235294117647059
193	121.25	121.25107.92987012987012987012987013
222	139.375	139.375118.41477707006369426751592357
255	159.375	159.375140.82904109589041095890410959
255	159.375	159.375166.60609271523178807947019868
255	159.375	159.375200.78430379746835443037974684
255	159.375	159.375221.46585365853658536585365854
255	159.375	159.375229.28335329341317365269461078
26	15	1553.542252
20	11.25	11.2516.354285714285714285714285714
I ran the log file through MJs log analyzer to calculate the load, and you can see that the results work pretty well.
Old Sep 24, 2006 | 06:33 PM
MalibuJack's Avatar
I'm impressed.. I was always hoping there would be an actual load.. But I'd need to see a run where the load was around 220 or higher, outside the clipping range of the MAF/MDP sensor logging range to see if this works right..
Edit.. If you take the max value 255, you won't see a load over 159 if the formula is 0.625
and 159.375 if you use the 5x/8
Unfortunately this load value is also clipped, its impossible for it not to be..
However, it can be used as a check value to make sure the load calc algorithm is correct for your settings.. I guess this range might have applied if your max boost is under 14psi or so (typical for older DSM's)
Old Sep 24, 2006 | 06:47 PM
chrisw's Avatar
I would have had a resonalbly decent run to the redline had the battery not crapped out in the laptop while driving...
Old Sep 24, 2006 | 06:51 PM
dan l's Avatar
But an older DSM (like my 90 eclipse) can use load values well into the 4grams/rev in the ecu AND send it to my pocketlogger. On the stock 1g ecu the load is a value from 0-255 decimal. What you do is divide this number by 128 to get a load value.
EDIT:
Who's to say that the x axis in ecuedit is labeled correctly? Why can't the load be from 0 to 3.00 grams/rev instead of a % value? Wheras the stock 1g DSM's were limited to 2.14 gram/rev (approximatley 215 wheel horsepower worth of "flow") it would make sence that an evo would have maps that go to 3.00 grams/rev (a value of 300% in ecuedit) or approximatley 300whp worth of "flow".
