Datalog Lab Dyno
Old Sep 24, 2006 | 10:10 PM
JDMSoapbox's Avatar
cool program
Old Sep 26, 2006 | 07:24 PM
EvOcHaRgeR's Avatar
So can you use the same cable that is used for ecuflash for this program?
Old Sep 26, 2006 | 07:30 PM
andenbre's Avatar
this program just reads your logs and maps them out, it doesnt actualy log itself
Old Nov 1, 2007 | 01:56 PM
Inprogress's Avatar
nj1266
Is the gear ratio the same for the EVO VIII and the EVO IX? Why did you use the EVO VIII as the car, I thought they had different gear ratios, wouldnt that effect the numbers it shows?
Old Nov 1, 2007 | 03:18 PM
kreionic's Avatar
inprogress, The ratio are
5 speed
1-2.785
2-1.950
3-1.444
4-1.096
5-0.761
6 speed
1-2.909
2-1.944
3-1.434
4-1.100
5-0.868
6-0.693
Old Nov 1, 2007 | 03:25 PM
Magnumpsi's Avatar
When I was tuning today I used it just to see how far off it was from my Mustang.
It was within 3 hp and torque was just about identical.
Really a cool feature.
Mitch
Old Nov 1, 2007 | 03:30 PM
SEEnoEVO's Avatar
Mitch
Wow. That is pretty impressive.
Old Nov 1, 2007 | 04:03 PM
jrsimon27's Avatar
Mitch
thats just great
Old Nov 1, 2007 | 11:00 PM
Inprogress's Avatar
Kreionic,
Thanks, but I guess I'm more interested in why nj1266 used the evo VIII as his base rather then creating a new one for his IX. It seems to inflate numbers when I switch car setting from the one I've created for the IX to the VIII
5 speed
1-2.785
2-1.950
3-1.444
4-1.096
5-0.761
6 speed
1-2.909
2-1.944
3-1.434
4-1.100
5-0.868
6-0.693
Old Nov 1, 2007 | 11:01 PM
Inprogress's Avatar
Mitch
That's friggin awesome! If you don't mind my asking, what do stock EVO IX's do on your dyno? Just for comparison is all, i know its just a number.
Old Nov 1, 2007 | 11:24 PM
nj1266's Avatar
Originally Posted by Inprogress
nj1266
That is an old thread. I used to have an Evo 8 and then traded it in for an Evo 9. The gear ratios do affect the numbers. Now I use an Evo 9 car definition file.
Old Nov 1, 2007 | 11:33 PM
cpoevo's Avatar
so how does this look for an VIII. It definitely shows where I am knocking. I am still working on the tune and trying to figure out how to use DLL. This is all I can do with DLL so far.
Old Nov 1, 2007 | 11:38 PM
Inprogress's Avatar
Thanks for the clarification!! and this thread!!
Old Nov 1, 2007 | 11:58 PM
nj1266's Avatar
You need to use higher smoothing factor to get rid of all the peaks and valleys in the chart. Try 8 or 9 and see how it looks. You can also use Tools>copy to sample graph to copy the power chart to the main chart on DLL. This way you can see the power overlayed with all the other variables that you logged.
Old Nov 2, 2007 | 12:02 AM
Inprogress's Avatar
What exactly does the smoothing factor help with? I know raising it shows lower numbers and lowering it shows higher...What's a good smoothing factor?
