Datalog Lab Dyno
Old Nov 2, 2007 | 12:12 AM
  #31
nj1266's Avatar
A Few more things that I need to update since I first posted in this thread:
1. The frontal area is actually 27.64. The one that I was using before was wrong.
2. To get the most accurate power graph from the log select garph contents until one data point after peak rpm. So if your peak rpm is 7688 and the next rpm point is 7500, then select 7500 rpm as the end point. You can do that by reducing the numbers in the "To" box.
3. Set your smoothing to 7 or 8 inorder to get the best looking chart.
Old Nov 2, 2007 | 12:22 AM
  #32
Inprogress's Avatar
what do you suggest for the weight since I have the SSL package? I know the sunroof and system upgrades must throw off the original 3263 figure
Old Nov 2, 2007 | 11:01 PM
  #33
nj1266's Avatar
The Evo 9 with SSL has a curb weight of 3338 lbs. Curb weight includes a full gas tank and all the fluids.
Old Nov 2, 2007 | 11:05 PM
  #34
Inprogress's Avatar
Sounds great, thanks!
I've also attached my dyno via DLL in case anyone's interested, pretty solid numbers if you ask me. I don't have anything to compare it to, but will hang on to it from now on to compare when I do upgrades in the future. Oh and the weight is factored as 245 for me + laptop, subs in the trunk, backpack, tools; just for clarification
Old Jan 14, 2008 | 07:02 AM
  #35
Thoe99's Avatar
Where did you find the frontal area? Most sources I've seen published says 24.92. This is the first time I've seen 27.64.
Old Jan 14, 2008 | 01:04 PM
  #36
Terry S's Avatar
Nevermind. Its up.
Terry S
Noize
29
Sep 27, 2016 05:18 PM
Chris@AMS
Sep 8, 2010 10:43 AM
TrinaBabe
88
Oct 31, 2007 03:04 PM
brodienuchies
Aug 20, 2007 09:54 AM
xtnct
Apr 29, 2003 07:54 PM
