is this timming ok??
Old Sep 23, 2006 | 11:06 AM
JrCRXHF's Avatar
is this timing ok??
is this look ok? i really do not know how much timing i can run i do have evo scan .9 so i will be looking for knock i have not done much with the fuel yet because i am still waiting on a wide band that will work with evo scan. For mods all i have is a cat back i do run only 93 oct here in michigan.
click me for the map
Old Sep 23, 2006 | 11:16 AM
C6C6CH3vo's Avatar
It's impossible to tell just from the appearance of a map
Old Sep 23, 2006 | 11:27 AM
JrCRXHF's Avatar
well other people have posted maps before and people have said how bad they are.
So i guess just try it and look at the data log.
Old Sep 23, 2006 | 07:11 PM
JohnBradley's Avatar
If everything is stock you can run more timing than that (specifically the map on the upper left). At least at stock boost levels you wont have any issues. Small steps, but look for something near 7 or 8 degrees at peak torque at stock boost. More depending on conditions. Alot depends on all of your other maps though, how lean it is, where the MIVEC is curved, etc.
Old Sep 23, 2006 | 07:55 PM
JrCRXHF's Avatar
ok thank you very much.
Old Sep 24, 2006 | 11:08 AM
cbrtrx's Avatar
you posted a graph of map 1, the car uses map 2 after it is at normal temp, not map 1
Old Sep 24, 2006 | 11:37 AM
JrCRXHF's Avatar
ok i did not know that.
so most of my changes should be made on map 2 on high oct.
Is that right?
Old Sep 24, 2006 | 07:58 PM
TTP Engineering's Avatar
Is that right?
Map 1 is the warmup map on Evo9. A good way to blow a headgasket is to modify that map.
Map 2 is normal operating temp map.
I suggest you contract a proficient Evo Reflash Tuner to do your first map so you can see the changes, and then make further adjustments customed tailored to your individual mods.
Hell sometimes we help more than the customer paid for when we have the free moment to do so.
PM me if you are interested in a basemap or custom RemotEflash for your mods.
Old Sep 25, 2006 | 05:27 AM
JrCRXHF's Avatar
I might take you up on that. I have tuned a few things from turbo FSAE race cars to my turbo honda on E-85 but i think that might have been a little more straight forward and i wanted to ask some questions about the car before i just jumped in.
in the long term what i would like to do is have dual maps in the car one for e-85 and on for 93 oct. I don't know if i can make this work with the stock high and low oct setup or in worse case i would have to reflash every time i wanted to change fuel.
