Throttle hang and the Idle Stepper Table
Old Aug 22, 2008 | 05:00 AM
  #331
CGroovy2k2's Avatar
Thanks...don't get me wrong, I love my EVO, but its almost like having a kid, you don't know whats wrong and you want to help but you need a specialist. Still a good kid but every now and then they get sick.
Old Aug 22, 2008 | 05:01 AM
  #332
CGroovy2k2's Avatar
If any EVO gurus, shops, anyone know what I need to do to fix this please help!
Old Aug 22, 2008 | 07:42 AM
  #333
biggie5252's Avatar
What do your idle tables look like? Maybe your throttle cable is stuck, or theres something sticking the throttle plate open.
Old Aug 22, 2008 | 09:51 AM
  #334
CGroovy2k2's Avatar
checked the throttle cable and its routed right in all the clips and there's no bends or binding. Not sure about the tables as I just had it tuned on the dyno not too long ago.
Old Aug 25, 2008 | 08:40 AM
  #335
CGroovy2k2's Avatar
bump for some help
Old Aug 25, 2008 | 07:34 PM
  #336
biggie5252's Avatar
Have you logged anything? Like throttle position, ISCV steps, etc?
Old Aug 26, 2008 | 10:15 AM
  #337
CGroovy2k2's Avatar
going to try and do that this weekend (if theres no rain) and see if I can solicit some help from AMS, TTP, Burchur somebody. I'll log and post what I can.
Old Aug 26, 2008 | 11:16 AM
  #338
TTP Engineering's Avatar
Originally Posted by CGroovy2k2
I know I'll probably catch hell for not reading all 22 pages...but from the pages I did read some of you have the same problem I have but mine seems to be worse.
My 8 will actually not just hang or climb 400 RPM. My RPM will actually keep rising up to 2000 RPM. For all the smart @$$es...no my foot is not on the gas, no im not hitting the clutch before I get off the gas, nothing like that. Actually I can take my foot off the gas and put it flat on the floor while the RPM's climb. Like others, its not all the time. It happens even when not driving hard. I can be cruising on my way to work and shifting the car like you would if a cop is right next to you and BAMM! the RPM's shoot up 2000-2500.
Check all the vacuum hoses on the back of the intake manifold.
There are 21 hose connections on the intake manifold, TB and EGR.
Whenever it hangs, depress the clutch pedal to the floor twice and see if it drops.
Old Aug 26, 2008 | 11:25 AM
  #339
wesside's Avatar
I've had the egr vacuum line come off a few times under high boost and was caused similar to what his problems where. I ended up putting a zip tie on it, problem solved
Old Aug 26, 2008 | 11:28 AM
  #340
CGroovy2k2's Avatar
I'll try that today when I get out of work. Thanks a million for the suggestions. As soo as I get results I'll post them up.
Old Aug 26, 2008 | 11:39 AM
  #341
wesside's Avatar
as far as the normal 05-06 throttle hang I also did the idle stepper table fix
Old Aug 26, 2008 | 11:59 AM
  #342
A typical side effect however is a poor cold idle.
Old Aug 26, 2008 | 06:39 PM
  #343
CGroovy2k2's Avatar
Ok checked all vacuum lines and all is well. took it around and tried the clutch thing like you suggested Scott and it died down before I can hit the clutch twice. I'll try again tomorrow.
Old Aug 27, 2008 | 11:32 AM
  #344
mr2driver's Avatar
I am wondering if the acd is somehow causing these issues?
Old Aug 27, 2008 | 02:03 PM
  #345
biggie5252's Avatar
Care to explain?
