Can oil pressure be logged thru EVOSCAN
Old Oct 10, 2006 | 12:18 PM
mchuang's Avatar
Since we are logging thru the obd2 port should we be able to log the oil pressure if the address is found since the sensor is designed to throw a check engine light if the oil gets low enough to trigger the sensor? I would definetly find this benificial because I really dont like the idea of having an oil pressure gauge in my cockpit.
Old Oct 10, 2006 | 12:47 PM
RazorLab's Avatar
You do know that most electronic gauges use a control box that the pressure signal is fed to right? Meaning no lines full of oil in the cabin.
Old Oct 10, 2006 | 12:50 PM
MalibuJack's Avatar
I think the stock sensor is a pressure switch anyway, therefore although it may report to the ECU (I'm not even sure, I haven't looked at the wiring diagrams lately) it probably will only report a state and not actual pressure.
Old Oct 10, 2006 | 12:56 PM
sterdyevo's Avatar
no
Old Oct 10, 2006 | 12:59 PM
mchuang's Avatar
No didnt know never used an oil pressure gauge expect for one to test vtec pressure lol
Old Oct 10, 2006 | 01:03 PM
mchuang's Avatar
Yea that is what I was stating the pressure. But if it is logging the pressure and you notice that it has changed significantly that can be an indication of bad bearings or other things like leaks. But you are the genius I am just throwing out ideas lol.
Old Oct 10, 2006 | 01:04 PM
RazorLab's Avatar
also, usually you have the oil pressure sensor screwed into the block or somewhere else, the electrical goes off that and goes into the gauge in the cabin, there is no reason to have lines of oil anywhere.
Old Oct 10, 2006 | 01:16 PM
KevinD's Avatar
it is not logging the pressure. it is a switch, meaning on or off. if you have pressure, there will be no light, if you have no pressure, the switch is on (or off which ever way you want to define it) and the light will turn on.
therefore tapping into this signal wire will not give you any pressure, it will most likely be 5V or 0V. one or the other depending on if you have oil pressure or not.
if you want to log pressure buy a zeitronix WBo2 and a 3 wire oil pressure sensor (prefferably one that will thread into the stock oil filter housing ports. hook up the +5V map sensor wire to the first wire of the OP sensor. hook the second wire up to the Aux in, and the last wire to the sensor ground from the zeitronix. now when you run the zeitronix system you will get a pressure signal in the aux in. it will read 0-5V but you can convert that to pressure quite easily.
Old Oct 10, 2006 | 01:18 PM
jcsbanks's Avatar
On my UK/JDM IX the oil pressure has its own light. There is nothing wired to the ECU regarding oil pressure, so nothing loggable.
Old Oct 10, 2006 | 01:43 PM
MalibuJack's Avatar
I just checked my car, it has a oil pressure light also.. Looked at the wiring diagram and its definitely not wired to the ECU in any way.
Old Oct 10, 2006 | 03:00 PM
C6C6CH3vo's Avatar
I don't know about oil pressure, but one thing I can tell you is that blood pressure seems to be very consistant with the load respectfully (when using stock MAF).
Old Oct 10, 2006 | 03:20 PM
jcsbanks's Avatar
The highest systolic BP I have recorded is 290mmHg. Similar to my overboost fuel cut I suppose
Driv200
Nov 28, 2017 11:27 AM
Exsubie22
Jun 6, 2017 06:11 PM
Jason Price
Jun 1, 2016 08:06 PM
kenshi3
Aug 19, 2012 09:51 AM
jamie_v1
Oct 11, 2008 03:03 PM
