adjusting "boost cut"...
Old Oct 27, 2006 | 07:59 PM
DontRevMe's Avatar
Im getting a nice power cut in the upper rpm's in 4th gear when its cold out. My tuner looked at my logs and said we should adjust my boost cut values. Now is this all done at the "boost limit" box? And what do the values (245,235 ,etc) relate to? As in how far can i raise these numbers?
thank you
Old Oct 27, 2006 | 09:56 PM
vboy425's Avatar
make all of them to the max. it should be 319
Old Oct 28, 2006 | 06:27 AM
MalibuJack's Avatar
It relates to the load calculation.. 319 should effectively disable it.
Old Oct 28, 2006 | 12:30 PM
DontRevMe's Avatar
Thanks guys. Ill give it a shot.
Old Oct 28, 2006 | 05:00 PM
DontRevMe's Avatar
Ok, looks like my boost limit wasnt changed, not sure if the tuner thought it needed to be. Anyways, I changed it to 319 across the board, and adjusted my launch control. I guess when it cools down tonight ill find out if it did the trick.
Old Oct 28, 2006 | 05:21 PM
JohnBradley's Avatar
You can also adjust the boost cut timer (or whatever it is) and set it maxed and after those two changes boost cut is gone with a stock turbo (all that I can comment on).
Old Oct 28, 2006 | 07:00 PM
MalibuJack's Avatar
Actually on my car I set both.. Since I'm running a GT35r, and do hit loads over 300, I was concerned that there was the possibility that 319 didn't actually disable it, so I used the delay timer set as high as it would go also..
Old Oct 28, 2006 | 08:28 PM
DontRevMe's Avatar
im running 23~ on the stock turbo..but if i have the problem ill be sure to edit that next.
Old Oct 28, 2006 | 11:55 PM
EFIxMR's Avatar
sorry about that allan, i was sick that day (still am) and neglected to set your boost cut.
Old Oct 29, 2006 | 12:12 AM
DontRevMe's Avatar
Dont worry about it, i know how that goes...I made use of that 90$ cable
anything else you may have overlooked?
car runs strong man, impressing alot of people.
Old Oct 29, 2006 | 12:20 AM
EFIxMR's Avatar
when i tune cars i usually start with a fresh map, and since we dyno in 3rd and don't run into boost cut issues, the boost cut is what i typically set last when we get off the dyno. unfortunately, that day i had a huge stomach ache and could barely stand up straight. sorry for the inconvenience.
