tune for better gas mileage?
All it is is crossover percentages. One map is warmup and the other is full temp operation as far as I know. You can set it low like Lucas does and idle in open loop, or if you dont need additional fuel control that low, highway cruising (55-60% or above), around town (30%+), or higher if you want it to stay in closed loop longer.
John, I thought about doing it that way, but it was just easier right before I left on my trip to drop 104 into the coolant temp box. Yeah, there's a CEL but I have a C reader and check the codes weekly. Nothing but the usual codes expected for such a change. I might convert over to the load attenuation, we'll see but in my case I want to idle rich...cammed car that idles rock solid like stock is fun for me as well.
I have a quick question that's somewhat related. By making the ecu go into open-loop in low load and leaning it out in those areas, would it be possible to make a SES for rear o2 stop showing? I would make a mechanical fix, but I'm not sure if my dremel would cut it.
I apologize for dragging a thread back up from the dead, but I found it to be really interesting and I have a question. How can you tell when you're in open loop? Is there something you can log that will tell you whether you're in open or closed loop at any particular point?
edit: Sorry I misread. I was reading the trim during decel which is 0. During idle there are numbers in there indicating closed-loop fuel adjustments.
Are you sure O2FeedbackTrim always goes to 0 when you're in open loop? I have a log which shows some ~80 mph cruise, with throttle in the 30-35% range, with non-zero values for O2FeedbackTrim. It was my understanding from this thread that at more than ~20% throttle you'll be open loop. Then again, my load at those times is very low... do you only go open loop when both throttle and load are above the thresholds?
Anyway in open-loop the ecu stops making fuel adjustments so an indicator is the zeros in the O2feedbacktrim.
1. I was in closed loop, and MalibuJack was incorrect: we don't switch to open loop until somewhere past 35% throttle
2. I was in closed loop, and we don't switch to open loop unless both throttle and load are above certain thresholds
3. I was in open loop, and O2FeedbackTrim is not always 0 when you're in open loop
In open loop the car still makes fuel adjustments but its based on calculated air flow not O2 feedback. I can set my cruise AFR to what I want in the lower load maps and it is very nearly exactly what I put it to. For instance a 15.7 with my mods and injectors will yield a 15.5 AFR in cruise.
Tom, as far as I have been able to determine its an Either/Or situation. If the load exceeds the setting then it will go into open loop. If the throttle % is exceeded it will do the same, even if the other variable has not been met. You have to remember its based on RPM as well as load percentage so if you were at 3500 rpm at 80 mph (lets disregard throttle for a moment) your load will easily be in the 70-80 range. Cross reference that on the stock map at that RPM and its 95%, but at 4000 its 78% (for load). You could have been there just based on that or very close.
Code:
RPM Speed O2Feedback TPS Load2Byte 3269.531 77.050 -3 32.549 79.062 3277.344 77.050 -1 34.902 87.188 3273.438 77.050 -3 34.902 91.250 3277.344 77.050 -5 34.902 95.000 3281.250 77.050 -6 34.902 97.812 3289.062 77.050 -2 34.902 100.312 3289.062 77.050 -3 34.902 102.812 3296.875 77.050 0 34.902 102.812 3308.594 77.050 0 34.902 102.500 3316.406 77.050 0 34.510 100.938 3320.312 78.293 0 34.510 99.062 3332.031 78.293 -1 33.333 87.188 3332.031 78.293 -1 33.333 85.938
The adjustments based on the front O2 sensor are different than what you're talking about John. In closed-loop the ecu reads the AFR from the front O2 sensor and makes adjustments to get the AFR to 14.7 (or whatever the closed-loop fuel map is set to). So the O2FeedbackTrim you're reading is how much the ecu is adding or holding back fuel. When the O2FeedbackTrim starts reading all zeros then the ECU is reading off the high-octane/low-octane maps.
How did you get your car to cruise lean? Did you force open-loop on your car during cruise? I might try this and see what gas mileage I get because I drive like 100 round-trip these days.
