tune for better gas mileage?
Old Sep 20, 2007 | 01:22 PM
  #61
roger smith's Avatar
Originally Posted by Tom-05-MR
I'm sorry, I'm afraid I still don't feel like I understand. Here's a log excerpt below:
Code:
RPM       Speed    O2Feedback TPS     Load2Byte
3269.531  77.050   -3         32.549   79.062
3277.344  77.050   -1         34.902   87.188
3273.438  77.050   -3         34.902   91.250
3277.344  77.050   -5         34.902   95.000
3281.250  77.050   -6         34.902   97.812
3289.062  77.050   -2         34.902  100.312
3289.062  77.050   -3         34.902  102.812
3296.875  77.050    0         34.902  102.812
3308.594  77.050    0         34.902  102.500
3316.406  77.050    0         34.510  100.938
3320.312  78.293    0         34.510   99.062
3332.031  78.293   -1         33.333   87.188
3332.031  78.293   -1         33.333   85.938
If the stock Open Loop Throttle map forces you into open loop at over 20% throttle, then I should be in open loop. However, my O2Feedback is not zero, so either I'm in closed loop, or a zero for O2Feedback doesn't mean you're in closed loop, or I'm not understanding something.
There it is going into open-loop when you reach 100 load. The reading isn't instantaneous for some reason as with items that get logged, like load error (but that's off-topic so nevermind). My car does the same. Open-loop load map at 3000/3500 is about 85 or 90 right? You're over that 85 or 90.
The throttle requirement for that rpm is over 60% I think because the map says 3 volts.
So you're meeting the load requirement. You don't need to meet both load and throttle requirements.
If you had a wideband you'll probably see your AFR start going richer in that area.
Old Sep 20, 2007 | 01:47 PM
  #62
Tom-05-MR's Avatar
Ah! I see. The problem I had was that in this post MalibuJack says the open loop threshold is at about 20% throttle, so I thought to myself that I should be in open loop based on throttle alone. So... from what you've said, I guess the TPS is a 5 volt sensor, and you can just divide the value in the map by 5 (and multiply by 100) to get throttle percentage?
Old Sep 20, 2007 | 01:55 PM
  #63
Yup, or multiply by 20 might be easier. [voltage]*20 = throttle percentage
gkswhdl88
Oct 14, 2015 08:34 PM
MitsuJDM
Sep 23, 2015 11:06 PM
fqjdmct9a
E85 / Ethanol
15
Feb 13, 2013 04:58 PM
stanrc
Aug 26, 2009 08:04 PM
Ariofighter
23
Jun 26, 2004 09:54 PM
