EVOscan love for PLX?
Old Nov 14, 2006 | 12:57 AM
evo4mad's Avatar
https://www.evolutionm.net/forums/sh...31#post3668831
Old Jan 6, 2008 | 01:22 PM
RelentlessEVO's Avatar
Hamish,
The PLX M-300 does not come with a serial port, as far as I know. So how can I connect it to my laptop to get you the .csv file? I really would love to get my current WB to work with EvoScan (which I have purchased and now use, instead of ECU+ which had already been installed on the car before I got it).
Can anyone explain to me how to hook up the M-300 to my laptop?
-Bill
Old Jan 6, 2008 | 03:42 PM
evo4mad's Avatar
it should be simple, you just need to get the data inputted via a comport. you can get innovate devices that takes a voltage input from any source (plx,300 if it has one) and hook it to evoscan. some evos, and if you are into programming, you can connect it directly to one of the spare ADC ports on your ecu, and log it directly from the ecu. I haven't done it, but i know its possible.
Old Jan 6, 2008 | 03:43 PM
evo4mad's Avatar
or sell your PLX and get a ZT2 or LC1
Old Feb 22, 2008 | 11:42 AM
silex's Avatar
Once I finish hooking up my PLX R-500, I will try to get a .csv over to evo4mad. It connects via USB which is translated to a serial comm port so it should fit the bill. I still don't believe that PLX widebands are still not supported since 1.5yrs after this post.
Old Feb 22, 2008 | 04:53 PM
evo4mad's Avatar
yeah send it on over. I'm doing more wideband support development today for v2.2
Old Feb 22, 2008 | 09:09 PM
silex's Avatar
Should have the .csv for you over the weekend
Old Aug 13, 2009 | 12:21 PM
SWOLN's Avatar
Was this ever resolved ? Thanks
Old Aug 13, 2009 | 03:26 PM
gear head's Avatar
I have mine wired into the ecu as per this thread....
https://www.evolutionm.net/forums/ec...ial-cable.html
Old Sep 15, 2009 | 05:58 PM
funks's Avatar
They also have a newer unit out which also supports SERIAL LOGGING (EvoSCAN doesn't support it though) and daisy chaining - similar to Innovate (MTS).
The dongle thing (converts serial -> USB) uses FTDI drivers, my assumption is that it just shows up as a virtual com port under windows, just a matter of parsing its data output. Some of the older units didn't have serial output..
The SM-AFR + MD5 Gauge can be had for 240$ (StreetRays.com). The USB Dongle Cable thing costs 66$ dollars though.
They also have the M300 Tuner Edition
Can be had for 270$ (StreetRays.com), also needs the optional serial dongle cable though if logging via computer.
Old Sep 17, 2009 | 10:59 PM
funks's Avatar
Hamish,
PLX iMFD serial protocol info
I believe the following code will work (as an example), I'll verify it once the controller get's here..
PHP Code:
using System;
using System.Collections.Generic;
using System.Text;
using System.Threading;
using System.IO.Ports;
namespace PLXWidebandReader
    class Program
        static void Main(string[] args)
            Console.WriteLine("Defaulting to PLX on COM4, testmode enabled.");
            IWidebandReader reader = new PLXWidebandReader("COM4");
            // IWidebandReader reader = new PLXWidebandReader("COM4", 1, new PLXWidebandReader.fuelTypeFunction(new PLXWidebandReader.FuelType().Gasoline));
            ((PLXWidebandReader)reader).TestMode = true; // keep looping through test packet
            reader.Start();
            Console.WriteLine("Timestamp,AFR");
            for (int i = 0; i < 1000; i++)
                Console.WriteLine("{0:o},{1:F2}", DateTime.Now, reader.LatestReading);
                Thread.Sleep(250);
            reader.Stop();
    interface IWidebandReader
        double LatestReading
            get;
        void Start();
        void Stop();
    class PLXWidebandReader : IWidebandReader
        private Object locker = new Object();
        private fuelTypeFunction fuelCalcFunction;
        private double latestReading;
        public double LatestReading
            get { return latestReading; }
        private readonly int instanceNumber;
        private SerialPort comPort;
        private Thread worker;
        bool continueRunning = false;
        // test related bits
        int sampleBytePacketIndex = 0; // this is only used for testing.
        private bool testMode = false; // if true, test mode
        public bool TestMode
            get { return testMode; }
            set { testMode = value; }
        public PLXWidebandReader(String comPortName)
            : this(comPortName, 1, new fuelTypeFunction(new FuelType().Gasoline))
        public PLXWidebandReader(String comPortName, int instanceNumber)
            : this(comPortName, instanceNumber, new fuelTypeFunction(new FuelType().Gasoline))
        public PLXWidebandReader(String comPortName, int instanceNumber, fuelTypeFunction fuelType)
            if (false == IsSerialPortNameValid(comPortName))
                throw new ArgumentException(comPortName + ", is invalid.");
            if (instanceNumber < 1 || instanceNumber > 32)
                // Note: 1 should be passed if there's only one AFR module.
                throw new ArgumentOutOfRangeException("instance number is required to be between 1 and 32.");
            init(comPortName);
            this.fuelCalcFunction = fuelType;
            this.instanceNumber = instanceNumber;
        private bool IsSerialPortNameValid(String comPortName)
            bool serialPortNameValid = false;
            foreach (String serialPortName in SerialPort.GetPortNames())
                if (true == serialPortName.Equals(comPortName))
                    serialPortNameValid = true;
            return serialPortNameValid;
        private void init(String comPortName)
            comPort = new SerialPort();
            comPort.PortName = comPortName;
            comPort.BaudRate = 19200; // per iMFD 19200 baud
            comPort.DataBits = 8; // per iMFD 8
            comPort.Parity = Parity.None; // per iMFD N
            comPort.StopBits = StopBits.One; // per iMFD 1
            comPort.Handshake = Handshake.None;
         * This method is only used for testing
        private byte GetByteFromSamplePacket()
            byte[] packet = { 0x80, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x00, 0x05, 0x00, 0x01, 0x00, 0x00, 0x0F, 0x40 };
            if (sampleBytePacketIndex >= packet.Length)
            return packet[sampleBytePacketIndex++];
        private double GetDataFromPacket(List<byte> packetContentBuffer)
            double afrReading = 0;
            for (int i = 1; (i + 5) < packetContentBuffer.Count ; i = i + 5)
                // Address MSB == 0 && Address LSB == 0 is a wideband.
                if (0 == packetContentBuffer[i + (int)PacketDataOffset.AddressMSB] && 0 == packetContentBuffer[i + (int)PacketDataOffset.AddressLSB])
                    // instance number is ordinal, 0-based.  Need to add one before comparing.
                    if (instanceNumber == ((packetContentBuffer[i + (int)PacketDataOffset.Instance]) + 1))
                        // we found the correct instance number
                        int dataMSB = packetContentBuffer[i + (int)PacketDataOffset.DataMSB];
                        int dataLSB = packetContentBuffer[i + (int)PacketDataOffset.DataLSB];
                        afrReading = fuelCalcFunction((dataMSB << 6) | dataLSB);
                        break;
            return afrReading;
        private void InitiateReading()
            List<byte> packetContentBuffer = new List<byte>();
            bool packetStarted = false;
            while (true == continueRunning)
                try
                    byte aByte = 0;
                    if (testMode)
                        aByte = GetByteFromSamplePacket(); // test packet
                    else
                        aByte = (byte)comPort.ReadByte(); // to read from the serial port
                    switch (aByte)
                        case 0x80:
                            // start byte
                            packetContentBuffer.Clear();
                            packetContentBuffer.Add(aByte);
                            packetStarted = true;
                            break;
                        case 0x40:
                            // stop byte
                            if (packetStarted)
                                latestReading = GetDataFromPacket(packetContentBuffer);
                            Thread.Sleep(0);
                            break;
                        default:
                            if (packetStarted)
                            break;
                catch (ThreadInterruptedException)
        public void Start()
            lock (locker)
                if (null == worker || false == worker.IsAlive)
                    continueRunning = true;
                    comPort.Open();
                    worker = new Thread(new ThreadStart(InitiateReading));
                    worker.Start();
                else
                    throw new InvalidOperationException("Already started.");
        public void Stop()
            lock (locker)
                if (true == continueRunning)
                    worker.Join(TimeSpan.FromSeconds(5));
                    if (true == worker.IsAlive)
                        // if worker is still alive, most likely still blocked on readByte, interrupt
                        worker.Interrupt();
                    comPort.Close();
                else
                    throw new InvalidOperationException("Not started.");
        public class FuelType
            public double Lambda(double x)
                return (x / 3.75 + 68) / 100d;
            public double Gasoline(double x)
                return (x / 2.55 + 100) / 10d;
            public double Diesel(double x)
                return (x / 2.58 + 100) / 10d;
            public double Methanol(double x)
                return (x / 5.856 + 43.5) / 10d;
            public double Ethanol(double x)
                return (x / 4.167 + 61.7) / 10d;
            public double LPG(double x)
                return (x / 2.417 + 105.6) / 10d;
            public double CNG(double x)
                return (x / 2.18 + 117) / 10d;
        enum PacketDataOffset : int { AddressMSB = 0, AddressLSB = 1, Instance = 2, DataMSB = 3, DataLSB = 4 };
        public delegate double fuelTypeFunction(double x);
Old Sep 18, 2009 | 02:46 AM
evo4mad's Avatar
thanks funks, i'll add that PLX parser to my code now, cheers.
Old Sep 24, 2009 | 08:37 PM
funks's Avatar
evo4mad,
I updated the source sample above, made it more readable (the old one was harder to follow - lol). Nevertheless, I tested the code on my car - works just fine. I'm getting about 10 samples per second which is in-line with the iMFD docs..
Old Sep 25, 2009 | 12:11 AM
codgi's Avatar
Code with my comments:
Code:
Any reasons why you check the validity of the first two arguments but not the last?
Code:
Is the same as
Code:
             if (!IsSerialPortNameValid(comPortName))
Code:
            for (int i = 1; i < packetContentBuffer.Count; i = i + 5)
                // make sure we don't overrun our buffer
                if ((i + 5) < packetContentBuffer.Count)
If you use a variation of the condition in the if statement as the ending condition for the for loop, you don' t need this if statement.
As before
Code:
                if (continueRunning == true)
Can be
Code:
if (continueRunning)
Nitpicking I know but....
Old Sep 25, 2009 | 12:39 AM
funks's Avatar
Damn, code ****! - lol.
I just like being verbose - updated sample posted above. I also wrote a sample LM1 Wideband Reader, if anybody would like to test it out for me, that would be great. Somebody else might find it useful.
