WHAT RPM IS YOUR 2 Step LAUNCH SET AT?
Old Apr 14, 2007 | 09:51 AM
  #91
supersnow's Avatar
It does knock but it your car is properly tune it'll recover right away, the ECU work lighting fast so let say you fall back to 5000 rpm after launching, as you accelerate without knock the ecu willswitch back to high octane maps
Old Apr 14, 2007 | 09:57 AM
  #92
eponti's Avatar
I set mine at 5500
Old Apr 14, 2007 | 04:11 PM
  #93
SLO-EVO's Avatar
Originally Posted by TylerBlueEvo8
7k on pump gas @ 20 psi, 8k on race gas @ 30 psi.
are you serious? youve got to be kidding...
(not bashing just find that a little high)
Old Apr 14, 2007 | 04:21 PM
  #94
evo8fl's Avatar
5500 is more then enough I get 1.6 or 1.7 at the track
Old Apr 16, 2007 | 02:07 PM
  #95
bboypuertoroc's Avatar
Veteran: Army
6000 rpms. Cut a 1.6 set at 5000 rpms when I was stock (only once) but stayed consistently in the low 1.7's. Keep it conservative until you get a better clutch.
Old Apr 17, 2007 | 12:02 AM
  #96
4TUN8's Avatar
6500....I'm going to go lower, with my power level now it spins too much.
  #97
newimportowner's Avatar
5800
Old Apr 18, 2007 | 06:12 AM
  #98
gvillevo's Avatar
5500 with 1.7's usually, stock clutch and all
Old Apr 19, 2008 | 05:09 PM
  #99
Johnboy1065's Avatar
never noticed what mines at. I'll take it out in a min and see.
Old Apr 19, 2008 | 05:13 PM
  #100
boostedwrx's Avatar
6K and it launches perfect on the street. Havent taken it to the sticky track yet..
I think the clutch restrictor also plays a big factor. I still have mine in and can basically side step it and it's fine.
Old Apr 19, 2008 | 05:21 PM
  #101
staatz's Avatar
6800 here
Old Apr 19, 2008 | 05:58 PM
  #102
EVOllie's Avatar
6800 all last year
Anything under 6k wont build boost on my car. 6k-7k bulids the same boost though. im going to play with it this year at the track(6k-7k) till i find the sweet spot or till it breaks.
Old Apr 21, 2008 | 09:37 AM
  #103
Levar's Avatar
Veteran: Army
I have mine set at 5500. Is this too low considering the type of clutch I have? Also, with is set at 5500, I'm quickly at 7400 (shifting point) which eliminates first gear for the most part. Does anyone bypass first gear altogether in order to get the most out of second gear?
Old Apr 21, 2008 | 09:41 AM
  #104
dahuii77's Avatar
5500 bro thats it..................
Old Apr 21, 2008 | 09:44 AM
  #105
silver9mr's Avatar
6100 anything under that i just kept bogging and still do with it now lol
