new to ecuflash logs to look at
Old Dec 5, 2006 | 04:02 PM
sandm's Avatar
I am new to the whole concept of ecuflash and am trying to gain an understanding of my logs prior to messing around with anything. I did 2 logs using malibujacks mitsulogger, and have tried to open in dataloglabs, but am unsure how to get the data to show up.
anyway, here are the 2 logs. one is a 1-3 gear pull at wot, starting at a low speed, and the second one is a wot 3rd gear pull from 2k to over 7k.
any thoughts or comments are appreciated.
waiting for a wideband/egt from ttp engineering so I can really have an understanding of what is going on, and for jack to get mitsulogger 2.0 with zeitronics support running
File Type: zip
File Type: zip
Old Dec 5, 2006 | 04:52 PM
nj1266's Avatar
I looked at your 3rd gear log in DLL and you seem to be running 7-8* of timing @ peak boost/ torque. You also have the onset of 2 counts of knock. 7-8* of timing in this area is just too much in my book. 3-4* is more acceptable on 93 octane gas and less than that on 91 octane gas.
What are your mods, btw?
Old Dec 5, 2006 | 05:07 PM
sandm's Avatar
06 evo9, rnr turboback with hf cat, buschur intake, walbro, forge mbc, rnr licp and frontmount and a dynoflash ttm.
run 93octane religiously.
hitting 21psi.
Old Dec 5, 2006 | 05:09 PM
sandm's Avatar
and the question of the day is how to view in dll?
I tried and couldn't get it to show anything. just a straight colored line at the bottom of the screen.
Old Dec 5, 2006 | 05:22 PM
RazorLab's Avatar
You need the right Def file loaded into DLL to view mitsulogger files. It's on this board in one of the DLL threads.
Old Dec 5, 2006 | 06:15 PM
nj1266's Avatar
Here is the definition file that you will need to upload to DLL
https://www.evolutionm.net/forums/at...chmentid=99783
Old Dec 5, 2006 | 06:47 PM
sandm's Avatar
have all that. still just a colored line at the bottom of the page.
must not be doing something right.
Old Dec 5, 2006 | 07:27 PM
RazorLab's Avatar
Do you have more than one data item checked off on the left?
Old Dec 5, 2006 | 10:01 PM
C6C6CH3vo's Avatar
Thats quite alot of timing for a IX.
That would be aggressive for a VIII which appear to run a bit more timing.
Was the 3rd gear pull done uphill? If not then understand that there's easily 40 to 50 WHP available with tuning alone
Old Dec 7, 2006 | 06:31 AM
sandm's Avatar
nope, flat road. I think that there is still a ton of hp left, as it was not road tuned. still want to know how to view logs. can someone post one from dll on here so I can see what the settings are I should be checking?
I tried with timing and knock checked, but didn't change anything else...
thanks for the help...
Old Dec 10, 2006 | 03:30 PM
sandm's Avatar
bump for anyone that can help me get this dll program working right...
Old Dec 10, 2006 | 04:17 PM
RazorLab's Avatar
Here is a screenshot with one of your logs opened in DLL:
Old Dec 12, 2006 | 03:36 PM
sandm's Avatar
I don't have a lot of the car options to pick from under data item, nor do I have anything under the column of preset graphs, and mine at the top says (utec csv data log)...
thoughts?
god I hate programs without manuals
Old Dec 12, 2006 | 04:02 PM
RazorLab's Avatar
That's why, you need to use the correct def file and select Universal Data format.
Put the evoscan or mitsulogger def file here:
C:\Program Files\DataLogLab\Universal Data Log Formats\
Change the app to Universal Data log format by doing this:
"if you ever want to be given the option of choosing your ECU type again, simply delete the DataLogLab.ini file within the Program sub-directory of the installation directory (if you’ve installed to the default location this will be C:\Program Files\DataLogLab\Program\DataLogLab.ini). PLEASE BE AWARE THAT THIS WILL RESULT IN THE LOSS OF ALL CHANGES YOU HAVE MADE TO THE APPLICATIONS CONFIGURATION SINCE FIRST RUNNING IT."
Old Dec 12, 2006 | 04:11 PM
RazorLab's Avatar
btw, here is online manual: http://www.flyinmiata.com/dataloglab...lpLauncher.htm
