ECUFlash / Evoscan / Mitsulogger Questions
Old Jun 9, 2015 | 06:08 AM
  #1621
sevic69's Avatar
Originally Posted by cdrinkh2o
Correct!
Thank you!
Old Jun 25, 2015 | 11:03 AM
  #1622
rbha's Avatar
logs
logs
File Type: bin
Old Jun 26, 2015 | 01:51 PM
  #1623
rbha's Avatar
evo 9 rs . low boost
Originally Posted by rbha
logs
Are these logs okay ?
Old Jul 2, 2015 | 05:52 PM
  #1624
CDrinkH2O's Avatar
Not sure what you mean. They show your engine idling and the values look OK.
Old Jul 3, 2015 | 11:20 AM
  #1625
Rax.'s Avatar
Is there any way to read and log V6 engine fuel consumption correctly with evoscan or similar program?
Old Jul 6, 2015 | 04:48 AM
  #1626
besk's Avatar
hi,i have EDM evo9 without ICS switch.
i had TDM old ROM 8858 i changed with TPS alt map and flash ICS lamp was working.
now i'm running usa rom 88591715 and i installed jot alt map harness kit,
flash ics isn't working anymore by TPS alt map and also not by ADC0F 1.
i think flash ics isn't working on alt map because it's a usdm rom and as you know usdm evo9 come without buld for ics.
how to fix it now on 8859?
Old Jul 31, 2015 | 07:44 PM
  #1627
mmmm-chase-good's Avatar
Hows it,
alright need help if possible, I have a 2001 Evo 7,
I'm running 95 Octane Fuel, 20G Turbo, have 700cc bosch injectors to put it, all piping is 3" from inter cooler onwards, fuel pump, and rail upgrades, the basic bolt ons,
can anyone help me with a base tune, looking to run 18-20PSI boost unless someone thinks other wise, also running a Greedy dual stage boost control & solinoide, and aftermarket exshaust system 3" with external Tail waste gate.
What power do you think I would be capable of ruffly? Living down in New Zealand, so temps are pretty mild here 0-24'c not sure what that is in Fahrenheit.
any help will be mint, pretty fresh in the tunning seen, have ECU flash and Tactrix cables, yet to pay for EVO scan is there anyway to get it for free
Old Jul 31, 2015 | 08:00 PM
  #1628
just about to buy evo scan, does anyone know if i have to buy a separate cable or can I just use my tactrix cable for evo scan also
Old Aug 1, 2015 | 01:01 PM
  #1629
evo8426's Avatar
Yes you can use it without issue. They are basically the same cable.
Old Aug 1, 2015 | 03:27 PM
  #1630
Charlescrown's Avatar
You will also need a wideband to monitor fuel mixture. You can directly log to the tactrix with a small xml file you read with excel. I can post one for the evo7 which I have setup. Took a lot to work out the wideband command line but it works fine so if you want a copy let me know and I will post it up.
Old Aug 1, 2015 | 03:34 PM
  #1631
I'm fresh as. Literally didn't know a thing on Friday and have been studying like crazy for the last two days. Getting everything sorted.
Any help man be awesome.
Email me if you like. Mmmm-chase-good@hotmail.co.nz
Old Aug 1, 2015 | 05:05 PM
  #1632
evoscan's Avatar
Silver Sponsor
Hows it,
Hey dude, EvoScan is made in New Zealand and Colby whom made Tactrix and OpenPort 2.0 used to live in the South Island of NZ
EvoScan and openport cables are made for each other.
take a look at our tuning guides and manuals.. come back with any questions, but those PDFs should keep you going for at least a few months of learning
http://www.evoscan.com/technical-veh...le-efi-systems
Old Aug 1, 2015 | 05:11 PM
  #1633
Cheers man. They will be handy. One thing I am having issues with is I'm wanting to set up semi launch control on the standard ECU.
The static rev limit doesn't seem to work.
Old Aug 18, 2015 | 10:19 AM
  #1634
danfalcas's Avatar
Wideband logging
Hi guys.
I wanto to log my AEM Wideband by conecting the output wire on the 75 PIN (Rear O2).
  • What consequences will I have? CEL? How can I remove it?
  • Can I log with MutsuLogger using the WBO2 connected to the Rear O2?
Thanks a lot!
Old Aug 22, 2015 | 10:17 PM
  #1635
Injector scaling
Hey guys I've just gone from factory 540cc injectors in my 2001 Evo 7
To 680cc injectors.
What do I need to change ? I've changed the injector scaling.
Is there a pulse count I need to change ? And what to ?
Or is it just injector scale and then tune octane maps?
Please help cheers
