ECUFlash / Evoscan / Mitsulogger Questions
Old May 18, 2020 | 11:28 AM
  #1771
kernelh's Avatar
Tried flashing my 2015 evo x gsr to a stock rom but I get an error saying tried to write to protected areas, Is there something I am missing? Had no issues with a 2011 gsr.
Old May 18, 2020 | 12:00 PM
  #1772
Biggiesacks's Avatar
X's are notorious for flashing issues, this guide should help you out.
https://evoscan.com/technical-vehicl...x-ecu-recovery
Also there is a bit about a registry mod that allows ecuflash to ignore protected memory areas here:
http://tephra.it/v3/
scroll down to "ECUFLASH Support". I don't now if this will work for you but might be worth a shot.
Old May 18, 2020 | 02:46 PM
  #1773
kernelh's Avatar
@Biggiesacks
Thank for the quick response, I will look into those links. Thanks again
Old May 21, 2020 | 09:56 AM
  #1774
Sliverbullet8's Avatar
Ecu rom questions
Hello I'm new to tuning my evo I'm trying to convert to flexfuel 91pump and e85. My Rom ID is 94170015 can I get a flex fuel tune with that ROM using free fuel or can I switch roms from 94170015 to 9653E706? I've tried searching and have not found a solid answer. Thanks in advance
Old Jul 12, 2020 | 10:50 PM
  #1775
markfromNZ's Avatar
Hi all - really, really long shot here. Evoscan "forums" link sends me here!
Wifey's car is a current model Eclipse Cross. Engine is a 1.5l turbo, Direct and port injected "4B40" - it drives quite well (far better than the previous 2.4 n/a offerings) but curiosity has the better of me given how well any turbo mitsi responds to a tune.
Not entirely willing to plug in my tactrix given the stories of other models getting bricked just from an ECU read - has anyone had any experience with this model? There's a couple of european tuning outfits offering "chips" but not keen to go that way if I can DIY it instead
Old Nov 30, 2020 | 11:20 AM
  #1776
GaBe511's Avatar
If i'm simply upgrading from stock injectors to 1000cc and mods are intake and exhaust, does EcuFlash have basic maps for that, or do you need to customize everything? The Hondata i have used had scaling already loaded for certain injector sizes.
Old Nov 30, 2020 | 11:22 AM
  #1777
Evo8life's Avatar
you have to dial them in yourself ecuflash has nothing to help you.
Old Nov 30, 2020 | 11:45 AM
  #1778
If its a common injector there will likely be known good scalings posted by other members you can just copy.
Old Nov 30, 2020 | 12:19 PM
  #1779
GaBe511's Avatar
Ok, thank you for the responses. Just wanted to be sure before i spent the money. I will get a proper tune, but to get me up and running it would be great if i can use the tactrix and ecuflash.
Old Nov 30, 2020 | 01:07 PM
  #1780
GaBe511's Avatar
Found this, is that what you are referring too?
Quote:
Originally Posted by PD1
PHP Code:
Code:
Code:
FIC 1000s
scaling 860
3.312
1.68
1.344
1.152
0.84
0.36
0.24
Quote:
Originally Posted by lan_evo_MR9
PHP Code:
Code:
Code:
FIC 1000
Pump Gas Scaling-835
E85 Scaling-636
Latencies
3.312
1.704
1.416
1.2
0.84
0.576
0.264
Old Nov 30, 2020 | 02:36 PM
  #1781
Yes those are injector scalings that you put into your ROM via ecuflash. No idea if those are the ones you need though, that depends on what injectors you have.
Old Nov 30, 2020 | 07:20 PM
  #1782
GaBe511's Avatar
I have FIC 1000s so theoretically those should be it.
Old Nov 30, 2020 | 07:39 PM
  #1783
Cool those should get you pretty close at least. You still need a tune though because there are a bunch of hard coded Pulse width values that need adjusting.
Old Dec 1, 2020 | 08:01 AM
  #1784
GaBe511's Avatar
Yea, i plan on getting a tune, just would rather drive it there instead of paying for more work.
Old Dec 1, 2020 | 08:55 AM
  #1785
Those are relatively small injectors so scalings should get you there. Other mods you may do at the same time may have an effect as well though.
